Chris Wilson Posted February 3, 2010 Share Posted February 3, 2010 If you input a VIN plate number (chassis number) will it show the correct engine part for the car where, without a VIN number it shows a choice? Specifically the on line parts list at http://www.toyodiy.com/parts/ shows at least two cam belt tensioner pulley assemblies when searching on a model year, what will happen with a VIN number inputed into the proper PC based EPC? Quote Link to comment Share on other sites More sharing options...
Kirk Posted February 3, 2010 Share Posted February 3, 2010 It should come up with the correct parts for that specific car Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted February 3, 2010 Share Posted February 3, 2010 (edited) input the katashiki code instead if possible, http://en.allexperts.com/e/t/to/toyota_katashiki.htm if u need any part number send me vin or katashiki and i will find it for you if you put without VIN it will show all possibility in the range cheers Edited February 3, 2010 by SupraGTE (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 3, 2010 Author Share Posted February 3, 2010 Where is this katashki code stamped please? Thanks for the kind offer. I am looking for part numbers for the cam belt tensioner pulley assembly, the crankshaft cam belt drive gear with the star trigger wheel attached for the crank position sensor, and actualm tensioner "cylinder" that applies pressure to the cam belt tensioner assembly I mentioned earlier. VIN number JZA80-0013255 Thanks It's a 6 speed manual TT, Jap spec. Quote Link to comment Share on other sites More sharing options...
Kirk Posted February 3, 2010 Share Posted February 3, 2010 Tensioner pulley - 13505-46041 Tensioner assembly 'cylinder' - 13540-46011 Crankshaft timing pulley - 13052-46010 Pretty sure thats where your after Quote Link to comment Share on other sites More sharing options...
Andy Blyth Posted February 3, 2010 Share Posted February 3, 2010 (edited) Where is this katashki code stamped please? On the VIN plate I belive Chris. A '93 Jspec TT6 is JZA80-ALFQZ if it helps. Edit: All possible values for JZA80 chassis: Edited February 3, 2010 by Andy Blyth (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted February 3, 2010 Share Posted February 3, 2010 So the car went out of factory october 1993 it is a silver 199 one , RZ Katashiki code is Jza80-alfqz -tensioner (the long green dildo)for cam belt is 13540-46011 -Tensioner pulley 13505-46041 -sliding bolt for tensioner 13556-46010 -pulley crankshaft timing 13052-46010 so same numbers as M_Life posted earlier Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 3, 2010 Author Share Posted February 3, 2010 Great, thanks guys, will order them up with confidence now, cheers. It is a 1993 model, and it is silver Long green dildo indeed, can't wait to ask for that.... Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 3, 2010 Share Posted February 3, 2010 Has anyone got a copy of the EPC I can download somewhere? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 3, 2010 Author Share Posted February 3, 2010 I may have yet another go at installing mine, Have yet to get it to work on three different PC's. Isn't there something about it not liking a big partition or something? What's the latest available version? Is it happy on XP? Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 3, 2010 Share Posted February 3, 2010 I downloaded one to, but couldn't work out how to install it, running Vista if that makes any difference. Quote Link to comment Share on other sites More sharing options...
Kirk Posted February 3, 2010 Share Posted February 3, 2010 Im running mine on vista paul. You need a program like winRAR to extract the files and then copy the region files to disc then upload them into the epc. You can either run them via disc or upload them on the hard drive so you dont have to keep booting them from the discs Usualy come with a tuturial on the download mate Quote Link to comment Share on other sites More sharing options...
Homer Posted February 3, 2010 Share Posted February 3, 2010 Has anyone got a copy of the EPC I can download somewhere? I have a copy of Nic's full EPC here if you need. It's about 3.5gb so too large to host, but can post a DVD if you don't find an online copy. Works fine on XP and Windows 7, not tried it on Vista. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 4, 2010 Share Posted February 4, 2010 I have a copy of Nic's full EPC here if you need. It's about 3.5gb so too large to host, but can post a DVD if you don't find an online copy. Works fine on XP and Windows 7, not tried it on Vista. That would be great mate. Quote Link to comment Share on other sites More sharing options...
garethr Posted February 4, 2010 Share Posted February 4, 2010 (edited) If you input a VIN plate number (chassis number) will it show the correct engine part for the car where, without a VIN number it shows a choice? Specifically the on line parts list at http://www.toyodiy.com/parts/ shows at least two cam belt tensioner pulley assemblies when searching on a model year, what will happen with a VIN number inputed into the proper PC based EPC? Could it be that there is a modified part which is a substitution for the earlier part number? Sometimes the EPC shows both part numbers with SUBS next to the later one. Edited February 4, 2010 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted February 4, 2010 Share Posted February 4, 2010 Could it be that there is a modified part which is a substitution for the earlier part number? Sometimes the EPC shows both part numbers with SUBS next to the later one. yes, it can be a supplier changed, modified part etc etc but should not matter what PN of those 2 PN you order as the are linked to eachother , example you order PN 001 , but you will receive 002 Btw my EPC is 16,4GB on my HDD this is the new version EPC from 2008 Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 4, 2010 Author Share Posted February 4, 2010 That's a LOT of part numbers It's good to have someone with inside info from Toyota on the forum! Quote Link to comment Share on other sites More sharing options...
