dandan Posted March 5, 2010 Share Posted March 5, 2010 Are these the rear subframe bushes? 48725-14070 Bush, rear axle carrier 48725F RH 48725-14070 Bush, rear axle carrier 48725G LH No Jamie. The ones you listed sit in the rear hubs and form the outer "bush" of the rear strut rod. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 5, 2010 Share Posted March 5, 2010 If the rear toe isn't set central to the chassis centreline it will be dire. I do it the old fashioned way and string it up off centreline datum points. Quote Link to comment Share on other sites More sharing options...
dandan Posted March 5, 2010 Share Posted March 5, 2010 (edited) From Nic's numbers....see attached pic RED...........52271-14080 Rear Mount Bush x 2 BLUE.........52205-14040 Rear Mount Bush RR-RH x 1 GREEN......52206-14030 Rear Mount Bush RR-LH x 1 YELLOW...52272-14040 Rear Upper Mount Bush x 1 There is also a 52273-14060 (SHOWN IN GREY) Stopper, Rear Suspension Member, Lower but I am not sure if you need this. Edited March 5, 2010 by dandan (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 5, 2010 Author Share Posted March 5, 2010 If the rear toe isn't set central to the chassis centreline it will be dire. I do it the old fashioned way and string it up off centreline datum points. It was only set up a couple of weeks back, something has to be wrong, is there anything else that holds the wheels straight other than the the four arms? Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 5, 2010 Author Share Posted March 5, 2010 No Jamie. The ones you listed sit in the rear hubs and form the outer "bush" of the rear strut rod. Im gonna speak with mike first, not sure if he changed them to powerflex or not. Quote Link to comment Share on other sites More sharing options...
dandan Posted March 5, 2010 Share Posted March 5, 2010 It was only set up a couple of weeks back, something has to be wrong, is there anything else that holds the wheels straight other than the the four arms? Has this problem appeared recently since the last alignment or been there a while? If it's been there a while, does it coincide with anything else - bush changes, ARB change, clipped a kerb etc? Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 5, 2010 Author Share Posted March 5, 2010 Has this problem appeared recently since the last alignment or been there a while? If it's been there a while, does it coincide with anything else - bush changes, ARB change, clipped a kerb etc? Its hard to say really, ive had so many problems with it feeling crap on the front and rear im a bit lost with it all tbh, im gonna change everything to brand new oem and go from there, rear first then if its still a problem change the front. When you are going for it at WOT i dont notice it so much, mainly when i hit a bump in the road at slow speed its apparent. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted March 5, 2010 Share Posted March 5, 2010 This is when Lee first fitted it, i think it may have settled a little lower now, its on its highest setting now, i think if i got another groove machined in i could raise it a tad but tbh i can just about live with the ride height as it is. http://i30.photobucket.com/albums/c338/jamie450x/billet022.jpg Sorry to go slightly off topic, but your car is so magnificently clean, it looks like a natural HDR photo! Gorgeous. Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 5, 2010 Author Share Posted March 5, 2010 Sorry to go slightly off topic, but your car is so magnificently clean, it looks like a natural HDR photo! Gorgeous. Thank you very much, stonkin put the hard work in that:) Quote Link to comment Share on other sites More sharing options...
pete_TT Posted March 5, 2010 Share Posted March 5, 2010 I changed all my arms/bushes for new OEM parts and it transformed it. Felt like a totally different car, well worth the money in my opinion. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted March 5, 2010 Share Posted March 5, 2010 Thank you very much, stonkin put the hard work in that:) Thank you mate Quote Link to comment Share on other sites More sharing options...
JODY T Posted March 5, 2010 Share Posted March 5, 2010 (edited) Got a problem with the car, i hit a small ridge in the road and its as if the front end steps over a couple of inch, feels very odd, ive booked to car into wheels in motion for friday afternoon to see if they can find anything, any ideas where to start? or anyone had a similar problem? Im not sure the car has ever felt right since going full powerflex bushes, the front just dont feel planted anymore, tempted to go back to new oem everything. Have u had the steering rack bushes replaced with poly ones? I had this very same problem on a car i did for a customer.. Turned out that the poly bush was wearing super quick and was alowing the rack to move sideways by about an inch.. Worth a look even if you havent changed this bush.. The rack has one bush that goes around the rack and one that stops it goings sideways.. Its probably this one... Edit: didnt read rest of the thread, changing everything should do it lol Edited March 5, 2010 by JODY T (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 5, 2010 Author Share Posted March 5, 2010 Cheers Jody, will get Lee to check it out. Quote Link to comment Share on other sites More sharing options...
Kirk Posted March 5, 2010 Share Posted March 5, 2010 Have you got a printout of the geometry specs that i can look at? Maybe able to identify the problem that way? Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 5, 2010 Author Share Posted March 5, 2010 Have you got a printout of the geometry specs that i can look at? Maybe able to identify the problem that way? Not to hand, ill have a look tomorrow. Quote Link to comment Share on other sites More sharing options...
