Terminator Posted February 1, 2010 Share Posted February 1, 2010 One of my 90 degree valve stems is leaking, I hope just a new seal will be enough to fix. If not does anyone know of a good source for 90 degree valves. (Please note I am not looking for 90 degree valve extension, which appear to be readily available.) Link to comment Share on other sites More sharing options...
tooquicktostop Posted February 1, 2010 Share Posted February 1, 2010 is it these you are looking for ?? http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MCYCLE&pcode=BBTVB1508 Link to comment Share on other sites More sharing options...
dandan Posted February 1, 2010 Share Posted February 1, 2010 I enquired about some a while back and was told that Envy could supply them. This was right around the time the company departed from the forum. Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted February 1, 2010 Share Posted February 1, 2010 I can supply them, not cheap though £15 each. Link to comment Share on other sites More sharing options...
Branners Posted February 1, 2010 Share Posted February 1, 2010 I had a valve go leaky on my first import, the tyre place fitted a 90 degree valve from a transit and it worked fine. Might be worth a go if desperate. Link to comment Share on other sites More sharing options...
Terminator Posted February 6, 2010 Author Share Posted February 6, 2010 Thanks for all the suggestions, if I cant repair it I might be after a set Ibrar. I think it is just the gasket that is failing as I can't clamp it down any tighter without stripping thre thread. Link to comment Share on other sites More sharing options...
