Fitz Posted February 1, 2010 Share Posted February 1, 2010 Following on from my last question regarding the Dash Removal. I'd also like to send the Drivers window control panel off to Kev too so he can work his magic but it appears to be stuck. I thought it was alot easier than this, but alas. Any help on this would be appreciated. (Attached are some images) Cheers Quote Link to comment Share on other sites More sharing options...
Fitz Posted February 1, 2010 Author Share Posted February 1, 2010 The pictures are off my phone so apologies for the poor quality. The last picture shows a screw of some kind, but I'm unable to reach it due to the door card being well in the way. Quote Link to comment Share on other sites More sharing options...
Rob Posted February 1, 2010 Share Posted February 1, 2010 Stubby screwdriver? I have done this, but it was several years ago. All I can say is it wasn't that difficult at all, which isn't a great deal of help but means you may just be overlooking something. Quote Link to comment Share on other sites More sharing options...
Fitz Posted February 1, 2010 Author Share Posted February 1, 2010 I don't think I have a screwdriver small enough to get in there. I heard it was quite simple to do but the bit I want off, is the only bit still on :S Quote Link to comment Share on other sites More sharing options...
Rob Posted February 1, 2010 Share Posted February 1, 2010 Flexi-shaft type screwdriver? Right angled adapter? Quote Link to comment Share on other sites More sharing options...
merckx Posted February 1, 2010 Share Posted February 1, 2010 I can't visualize which bit it is but can't you just use the screwdriver at a slight angle or just bend/cut a little bit of the door card out the way if it's hidden from view. It may be a torque head screw, if you haven't got a torque head bit then a flat bladed screwdriver can be used if it's not too tight. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 1, 2010 Share Posted February 1, 2010 See Heckler's how to guides here http://www.internetwork.org.uk/supra.htm Quote Link to comment Share on other sites More sharing options...
Fitz Posted February 1, 2010 Author Share Posted February 1, 2010 Most appreciated for the feedback guys. Quote Link to comment Share on other sites More sharing options...
Fitz Posted February 1, 2010 Author Share Posted February 1, 2010 See Heckler's how to guides here http://www.internetwork.org.uk/supra.htm Had a check in there Nic. Nothing to do with removing the window control unit. Just the Dash and Doorcards, which I know how to do. Thanks anyway Quote Link to comment Share on other sites More sharing options...
