2jz-gte valve covers
Guest KSTUNING
How do you remove the hose fittings on the 2jz-gte valve covers?
Just use force and pull them out?
Which hoses dude, the inner ones or outer, on the lnlet side there is a pcv valve which you can pull out if you want after the hoses are off.
Guest KSTUNING
Sorry for not beeing more specific...
I mean the outer hose fittings... 90 degree neck on exhaust side and straight out on the intake side...
The reason I ask is to avoid breaking something inside there... Want to remove them and put 10an fittings there instead...
Thanks! :)
Thanks! :)
Just pull em out dude, a bit of wiggling and grunting and they will be out, you will feel just like a dentist.
