Guest markb Posted January 31, 2010 Share Posted January 31, 2010 I have tried to start the engine but it won’t start. There is sufficient fuel, but not enough spark from the sparkplugs. I have checked all the spark plugs and they all barely sparked or didn’t spark at all. I have swapped the battery, but this didn’t help either. Same problem still. The engine was running ok for 2 weeks ago, but all of sudden the above mentioned problem occurred. There after the Supra has been standing outside, with an occasional snow “storm” having covered the Supra in a thick layer of snow. It’s a Supra TT BPU 1993 Quote Link to comment Share on other sites More sharing options...
trinitom Posted January 31, 2010 Share Posted January 31, 2010 have a look at the ignitor pack. edit-- are your spark plugs fine? Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 31, 2010 Share Posted January 31, 2010 What voltage are you seeing at the battery? If you kept the spare out in the cold it too may be drained. Usually though a drained battery is obvious in that the engine barely turns over. Have you got any dampness in the engine bay/plug wells? Quote Link to comment Share on other sites More sharing options...
Guest markb Posted January 31, 2010 Share Posted January 31, 2010 @trinitom I did try it with a new spark plug. How can I check the igniter pack? @Ian C The battery give 12V. We also tried with a other car and starting cables. The engine turs over fine. It's with a new spark plug a very weak spark. Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 31, 2010 Share Posted January 31, 2010 Substitution with a known good igniter is the best and easiest way of testing - is your other car a Supra? Quote Link to comment Share on other sites More sharing options...
