Red light
Guest Rottweiler
Guest Rottweiler
I`ve got a red warning light come in the centre or the tacho on my Supra. It`s a red triangle with an exclamatiom mark inside. No other lights have come up with it.If you switch the engine off and start up again it comes back on after a couple of miles.As my car is an import the manual`s in Japanese . Can anybody help `cos I dont want to damage the car. No noises and it seems to go ok.
It doesn't sound like the brake fluid issue. That, my man, is indicating you are storing a fault code. You need to check what fault code you are storing (a very simple process) and report back here with it so we can help diagnose what's wrong :)
Go here:
http://www.mkivsupra.net/vbb/showthread.php?t=35920
For instructions on how to check the codes. Bring a paperclip.
-Ian
