SamuraiFlash Posted January 30, 2010 Share Posted January 30, 2010 Hi Guys, I picked up my N/A auto today, and have been driving it all day long, i totally love it (Ill post pics tom) I have a few concerns. 1. The temp gauge doesnt go up much even after driving the car for many miles, the good thing is that once the engine has warmed up there isnt any smoke coming out of the exhaust. 2. the engine idles at 1,400 ish rpm, is this normal? 3. The car makes a little noise when turning to the left Ill be taking the car to Keron for a service and a thorough check. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 30, 2010 Share Posted January 30, 2010 (edited) Congratulations 1. The temp gauge doesnt go up much even after driving the car for many miles, the good thing is that once the engine has warmed up there isnt any smoke coming out of the exhaust. Nothing to worry about, the highest the temp gauge will normally go is half way, if it starts going into the red then it's time to worry. 2. the engine idles at 1,400 ish rpm, is this normal? NA's do tend to idle quite high. 3. The car makes a little noise when turning to the left What sort of noise, a whining noise? If so may be low PAS fluid. Worth giving it a service and fluid change. Edited January 30, 2010 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted January 30, 2010 Author Share Posted January 30, 2010 Thanks Nic i really appreciate that I'll will be taking her in for a service, but why is it so cold in the car even though i blast the temp to the highest Quote Link to comment Share on other sites More sharing options...
Dave17 Posted January 30, 2010 Share Posted January 30, 2010 Thanks Nic i really appreciate that I'll will be taking her in for a service, but why is it so cold in the car even though i blast the temp to the highest In that case if the temp needle barely moves it is likely to be in need of a new thermostat. Quote Link to comment Share on other sites More sharing options...
The Raven Posted January 30, 2010 Share Posted January 30, 2010 Some thing wrong there. The temp should go to half way quite quickly then stay there. The idle should start high then drop to just bellow 1k The noise? To hard to say but wheel bearing? Is it a knocking? Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted January 30, 2010 Author Share Posted January 30, 2010 In that case if the temp needle barely moves it is likely to be in need of a new thermostat. cheers ill get that checked out Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted January 30, 2010 Author Share Posted January 30, 2010 Some thing wrong there. The temp should go to half way quite quickly then stay there. The idle should start high then drop to just bellow 1k The noise? To hard to say but wheel bearing? Is it a knocking? The noise is a rattling noise What do you reckon could be wrong Raven? Quote Link to comment Share on other sites More sharing options...
The Raven Posted January 30, 2010 Share Posted January 30, 2010 Might be the heat shield under the car rattling, My old n.a used to do it at a certain speed. Best take the car to someone who knows supras and get the whole lot checked out. Quote Link to comment Share on other sites More sharing options...
devan Posted January 30, 2010 Share Posted January 30, 2010 My N/A idles at about 900RPM after its done its warm up mode thing. Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted January 30, 2010 Author Share Posted January 30, 2010 My N/A idles at about 900RPM after its done its warm up mode thing. That sounds normal, i'm not sure why mine is idleing so high I'll be taking the car to see Keron sometime next week. Quote Link to comment Share on other sites More sharing options...
The Raven Posted January 30, 2010 Share Posted January 30, 2010 That sounds normal, i'm not sure why mine is idleing so high I'll be taking the car to see Keron sometime next week. Keron will sort it out mate:) Dont be too worried about the idle a quick rest of the the car could sort that out. Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted January 30, 2010 Author Share Posted January 30, 2010 Keron will sort it out mate:) Dont be too worried about the idle a quick rest of the the car could sort that out. Thanks Raven, i feel better now Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted January 30, 2010 Share Posted January 30, 2010 Mine idled all over the place high and low until i had a major service done, now its spot on. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted January 30, 2010 Share Posted January 30, 2010 The temperature needle not moving much, and the idle always being high might be linked. Probably recapping what others have said here, but the temperature needle should be in the centre of the gauge after a few minutes' driving, and stay there. The cold idle can be as high as 2000rpm on an NA, but it should drop to about 900rpm, again after a few minutes' driving. The heater not getting warm could be caused by an old inefficient heater matrix (common problem, not easy to fix unfortunately, but it is fixable). or..... All of these symptoms *could* be caused by a lack of a thermostat altogether. It's possible to run most cars without a thermostat to counteract an overheating problem that the car might have. Without a thermostat, the temperature gauge will barely move off the cold mark no matter how long you drive it for. The car will use lots of fuel, and it definitely isn't recommended because it's a bodge to mask a problem. That would explain your high idle (because the engine's always in cold-idle mode), and also the cabin not getting warm (the cabin heater uses the same coolant as the engine. If the engine coolant doesn't get warm, neither will the heater). Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted January 30, 2010 Author Share Posted January 30, 2010 The temperature needle not moving much, and the idle always being high might be linked. Probably recapping what others have said here, but the temperature needle should be in the centre of the gauge after a few minutes' driving, and stay there. The cold idle can be as high as 2000rpm on an NA, but it should drop to about 900rpm, again after a few minutes' driving. The heater not getting warm could be caused by an old inefficient heater matrix (common problem, not easy to fix unfortunately, but it is fixable). or..... All of these symptoms *could* be caused by a lack of a thermostat altogether. It's possible to run most cars without a thermostat to counteract an overheating problem that the car might have. Without a thermostat, the temperature gauge will barely move off the cold mark no matter how long you drive it for. The car will use lots of fuel, and it definitely isn't recommended because it's a bodge to mask a problem. That would explain your high idle (because the engine's always in cold-idle mode), and also the cabin not getting warm (the cabin heater uses the same coolant as the engine. If the engine coolant doesn't get warm, neither will the heater). thanks stevie, looks like i have one of two problems, i just hope its the 2nd one, as ive read replacing the matrix can be expensive Quote Link to comment Share on other sites More sharing options...
pbryant_knight Posted January 30, 2010 Share Posted January 30, 2010 Mine idles quite high when you first start it up in the cold but then drops to 1k or just under when it's a bit warmer. Mine also has a buggered matrix and it's a pain to fix so i'm not even going to bother now. Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted January 30, 2010 Author Share Posted January 30, 2010 Mine idles quite high when you first start it up in the cold but then drops to 1k or just under when it's a bit warmer. Mine also has a buggered matrix and it's a pain to fix so i'm not even going to bother now. im just itching to take my car to Keron now just to get some answers. are there any supra specialists in birmingham? Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 8, 2010 Author Share Posted February 8, 2010 I got my Supra looked at, and there wasn't a thermostat installed This explains why i was always idling around 1500rpm even after driving for over 30mins. After i got a thermostat installed, my car is now idling around 1000rpm and the temp guage is in the middle where it should be, but the air coming into the cabin has warmed up but not warm enough so could be a heater matrix problem!!!! Do you guys reckon a previous owner was trying to mask an engine over heating problem? will i see this problem in the summer when the temp will be warmer? also what can i do to sort this potential problem out? install an intercooler? Quote Link to comment Share on other sites More sharing options...
marc_p Posted February 8, 2010 Share Posted February 8, 2010 I got my Supra looked at, and there wasn't a thermostat installed This explains why i was always idling around 1500rpm even after driving for over 30mins. After i got a thermostat installed, my car is now idling around 1000rpm and the temp guage is in the middle where it should be, but the air coming into the cabin has warmed up but not warm enough so could be a heater matrix problem!!!! Do you guys reckon a previous owner was trying to mask an engine over heating problem? will i see this problem in the summer when the temp will be warmer? also what can i do to sort this potential problem out? install an intercooler? Could of been trying to mask the heater matrix problem by removing the thermostat. Oh and N/A's don't have intercooler's Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 8, 2010 Author Share Posted February 8, 2010 Could of been trying to mask the heater matrix problem by removing the thermostat. Oh and N/A's don't have intercooler's I just hope its nothing too serious, i can live without hot air Oh its just that i thought i saw a few pics of n/a's with a front mounted intercooler? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted February 8, 2010 Share Posted February 8, 2010 I doubt it will be a FMIC, unless they were NA-T I would concentrate on enjoying the car and not worrying about it. IF problems occur, sort them when they occur Quote Link to comment Share on other sites More sharing options...
marc_p Posted February 8, 2010 Share Posted February 8, 2010 I just hope its nothing too serious, i can live without hot air Oh its just that i thought i saw a few pics of n/a's with a front mounted intercooler? If it's the heater matrix you won't want to leave it as the car will shit itself and probably warp the head. Oh and intercoolers are for supplying cold air to the turbo, it might of been N/A - T conversions you've seen. Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 8, 2010 Author Share Posted February 8, 2010 If it's the heater matrix you won't want to leave it as the car will shit itself and probably warp the head. I'll find out exactly what the problem is when i go to see Keron sometime this week, once he is free to see me. Oh and intercoolers are for supplying cold air to the turbo, it might of been N/A - T conversions you've seen. I apologise for being such a n00b Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 8, 2010 Author Share Posted February 8, 2010 I doubt it will be a FMIC, unless they were NA-T I would concentrate on enjoying the car and not worrying about it. IF problems occur, sort them when they occur I'm enjoying the Supra, its always been my Dream car - i'll be getting an N/a - TT conversion done once ive saved up enough. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted February 8, 2010 Share Posted February 8, 2010 I'm enjoying the Supra, its always been my Dream car - i'll be getting an N/a - TT conversion done once ive saved up enough. Crikey, you will be a bag of nerves if you do that Quote Link to comment Share on other sites More sharing options...
