dr_jekyll Posted February 9, 2010 Share Posted February 9, 2010 (edited) i dont see why people dont use the lexus ls400 4 pots , they use 315mm discs ,99.99% direct fir on a supra (1 small pice of filing literally 20 seconds) and they are ally so are verry light, lighter than uk specs. not to mention they were designed to stop a 1.8 tonne v8 car these are by far the best things i have put on my car Edited February 9, 2010 by dr_jekyll (see edit history) Link to comment Share on other sites More sharing options...
RobD Posted February 9, 2010 Author Share Posted February 9, 2010 No, definitely not New UK ones, especially at a good discount are the way to go unless you fancy splurging on a full kit from one of the big three? No, I think the uk ones will do me fine, perhaps if I ever get chasing Big BHP then I may opt for a couple of grands worth of brakes I think the quotes from work was £587 for the front and £525 for the rear! Link to comment Share on other sites More sharing options...
Abz Posted February 10, 2010 Share Posted February 10, 2010 Ever driven a Range Rover Sport? Still amazes me how the brembo brakes stop such a heavy car so well! Though Chris has a very valid point regarding brackets etc. Trust me Rob you will be fine with UK's & a decent pad setup (CW Pads are good along with endless & a couple other). I have JSpec's on mine & currently with OEM pads but I have some yellow stuff lying around which I might try. They are pretty good brakes though for normal driving & a bit of fast road, though track days they would be rubbish! Go UK & remember to get me my set when you do mate Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 10, 2010 Share Posted February 10, 2010 i dont see why people dont use the lexus ls400 4 pots , they use 315mm discs ,99.99% direct fir on a supra (1 small pice of filing literally 20 seconds) and they are ally so are verry light, lighter than uk specs. not to mention they were designed to stop a 1.8 tonne v8 car these are by far the best things i have put on my car So unlike the half cast iron, half cast alloy UK calipers these are all alloy construction? Link to comment Share on other sites More sharing options...
dr_jekyll Posted February 10, 2010 Share Posted February 10, 2010 im going leave the saftey on and say thats what the guy at the lexus/toyota garage told me told me. but he had both there and these were a noticeable amount lighter but pretty much the same size Link to comment Share on other sites More sharing options...
Suprab1 Posted February 10, 2010 Share Posted February 10, 2010 i dont see why people dont use the lexus ls400 4 pots , they use 315mm discs ,99.99% direct fir on a supra (1 small pice of filing literally 20 seconds) and they are ally so are verry light, lighter than uk specs. not to mention they were designed to stop a 1.8 tonne v8 car these are by far the best things i have put on my car Would these fit under 17s? Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 10, 2010 Share Posted February 10, 2010 They would fit under SOME 17 inch rims, certainly they should fit under stock UK / US / European rims, which are cheap and light, and of course, fit properly. Link to comment Share on other sites More sharing options...
dr_jekyll Posted February 10, 2010 Share Posted February 10, 2010 i just found out the lexus calipers are 6lbs lighter each than the uk calipers so i would say they would be all ally uk caliper = 15lbs over 323mm disc ls 400 = 9 lbs over 315mm disc if you have the corrdect offset they should fit under 17s Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 10, 2010 Share Posted February 10, 2010 So, have you actually got these Lexus calipers on stock uprights, over stock 323 mm MKIV UK front discs, on a MKIV? Have you looked at the rear calipers off the LS400? Link to comment Share on other sites More sharing options...
dr_jekyll Posted February 10, 2010 Share Posted February 10, 2010 no , i have these on stock uprights, on my j-spec mkiv using the lexus 315mm discs. as an upgrade from j-spec 2 pots. i have looked into the rear conversion but due to rear hub diferences i was told its a non starter Link to comment Share on other sites More sharing options...
Suprab1 Posted February 10, 2010 Share Posted February 10, 2010 Ok here's a pic of my 17" wheel, there is 6cm from the disc to the spoke and 1" from outside edge of jspec caliper to spoke on wheel. Do you think the ls400 calipers would fit behind my wheels? Link to comment Share on other sites More sharing options...
dr_jekyll Posted February 10, 2010 Share Posted February 10, 2010 its hard to say mate , its quiet a chunky caliper. after a quick whip arond unger the car with a tape mesure id say you need 180mm from the centre of the hub to the inner wheel and 70mm from the face of the disc to the spokes. Link to comment Share on other sites More sharing options...
Suprab1 Posted February 10, 2010 Share Posted February 10, 2010 Sound mate thanx, what would you think of small wheel spacers to get the clearance? i've read a few on the site doesn't recomend them, but if they were just thick enough to clear these brakes as i don't want to change my wheels. Link to comment Share on other sites More sharing options...
dr_jekyll Posted February 10, 2010 Share Posted February 10, 2010 if its just a few mm i shouldnt imagen it would make to much difference but im sure a more spacer knowlageble will be along to shed more light on it shortly Link to comment Share on other sites More sharing options...
Suprab1 Posted February 10, 2010 Share Posted February 10, 2010 Cool mate cheers. Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 10, 2010 Share Posted February 10, 2010 no , i have these on stock uprights, on my j-spec mkiv using the lexus 315mm discs. as an upgrade from j-spec 2 pots. i have looked into the rear conversion but due to rear hub diferences i was told its a non starter Do the outer edges of the pads overhang the disc at all? If they were a correct fit on a a 323 mm disc they would overhang by 4 mm. It would appear that they may not work on a UK size disc, which is a shame. I am pretty sure the pads are the same as UK MKIV caliper pads, if not there's still a chance they'd work on the bigger diameter discs.. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 10, 2010 Share Posted February 10, 2010 (edited) I'm going to look for some ls400 front calipers and ill buy a pir of brembo 2pot rear calipers off evo 8 as they fit straight on. I know someone selling the lexus ls400 mark 3 calipers from 1994, will these fit? Edited February 10, 2010 by SamuraiFlash (see edit history) Link to comment Share on other sites More sharing options...
dr_jekyll Posted February 10, 2010 Share Posted February 10, 2010 I'm going to look for some ls400 front calipers and ill buy a pir of brembo 2pot rear calipers off evo 8 as they fit straight on. I know someone selling the lexus ls400 mark 3 calipers from 1994, will these fit? no , you need the later and bigger ufc20 calipers. the earlyer ones were smaller and not verry good Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 10, 2010 Share Posted February 10, 2010 no , you need the later and bigger ufc20 calipers. the earlyer ones were smaller and not verry good Thanks Craig Link to comment Share on other sites More sharing options...
garethr Posted February 10, 2010 Share Posted February 10, 2010 ...Have you looked at the rear calipers off the LS400?The rears are solid discs, and opposed piston calipers with different mounting centres. Link to comment Share on other sites More sharing options...
garethr Posted February 10, 2010 Share Posted February 10, 2010 ...I know someone selling the Lexus LS400 Mark 3 calipers from 1994, will these fit? No, you need the later and bigger UCF20 calipers. The earlier ones were smaller and not very good Thanks Craig They may be the ones you want, 1994 was the changeover year. The earlier LS400 calipers (model code UCF10) were sliding calipers like the "J-Spec" Supra brakes, so it's obvious which is which. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 10, 2010 Share Posted February 10, 2010 They may be the ones you want, 1994 was the changeover year. The earlier LS400 calipers (model code UCF10) were sliding calipers like the "J-Spec" Supra brakes, so it's obvious which is which. If this is true then i'll be getting them for a good price. Link to comment Share on other sites More sharing options...
