Steering rack ball pin ends
David P
  • 2 weeks later...
  • 1 month later...
Could you get it here by Monday?
Might be interested if you can, copied versions cost nearly £60
I just bought a fairly decent looking, japanese made copy of one of these in my local motor factor's for €43.
Must be those short shorts I wear occasionally:eyebrows:
Spike,
As per pm.
If it helps you out, there is no rush for payment.
The pin end is wrapped and ready to go, but I have no address for you, I thought you needed it in a hurry?
I have included a second that is servicable, no slack, just not as tight as the other, this second one is free, just add £2 to cover P&P.
You still have dibs on this deal, please let me know what you want to do so I can answer the other enquiries.
Cheers
David
  • 2 weeks later...
I am not sure if this is what i need, car has just had MOT and the advisory suggests, replacing track rod end ball joint. Known as a drumstick apparently. Is this the same thing?
Nope.
The part you need is screwed onto this and is then connected to the wheel hub via a ball joint which in your case showed up in the MOT
Thank you for the info :) Hopefully Nic can help me out.
Nic ain't trading at the moment due to a long term health issue.
I'm sure the other traders would be able to supply what you need though, as would Toyota or even a decent motor factors would source suitable spurious items.
