Matt _Aero top_ Posted January 28, 2010 Share Posted January 28, 2010 Hi all What should the oil pressure be on idle and when the clog is down . just so i make sure i buy the correct gauge as i don't really want it off the scale as i have read it can be over 100psi when driven hard . Matt Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 28, 2010 Share Posted January 28, 2010 2JZ-GTE Workshop Manual Oil Pressure specs:- With engine at normal operating temperature, oil pressure should be at least 7.1 psi (.5 kg/cm) at idle and approximately 47-84 psi (3.3-5.9 kg/cm) at 3000 RPM. I'd get a capillary (not electronic) gauge that reads to about 120 PSI Quote Link to comment Share on other sites More sharing options...
JustGav Posted January 28, 2010 Share Posted January 28, 2010 Moved to tech. Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted January 29, 2010 Author Share Posted January 29, 2010 Cheers chris Quote Link to comment Share on other sites More sharing options...
