TrevS Posted January 27, 2010 Share Posted January 27, 2010 Hi all Just got my new Supra home and it appears the bonnet isn't sitting quite flush when its closed and sits up a little. I've avoided pressing down on the bonnet and instead tried dropping the bonnet from a little higher to avoid denting/benting it but it still doesn't look quite right. Any ideas on how to get the bonnet flush? Trev Quote Link to comment Share on other sites More sharing options...
nevins Posted January 27, 2010 Share Posted January 27, 2010 If its at the front leading edge, and up the wing adjust the rubbers on the slam panel. Quote Link to comment Share on other sites More sharing options...
Scooter Posted January 27, 2010 Share Posted January 27, 2010 There are twisty rubber bungs (one either side) that you can rotate in/out that can have an effect, i'd give these a go first...... Quote Link to comment Share on other sites More sharing options...
broomie Posted January 27, 2010 Share Posted January 27, 2010 Hi all Just got my new Supra home and it appears the bonnet isn't sitting quite flush when its closed and sits up a little. I've avoided pressing down on the bonnet and instead tried dropping the bonnet from a little higher to avoid denting/benting it but it still doesn't look quite right. Any ideas on how to get the bonnet flush? Trev try screwing the rubber grommits in/out till the bonnet sits right they are at the front on either side of the engine bay! oh beaten to it! Quote Link to comment Share on other sites More sharing options...
Kev.O Posted January 27, 2010 Share Posted January 27, 2010 Just above each headlight is a black rubber stopper. This simply twists down. Try altering that Edit: Way too slow Quote Link to comment Share on other sites More sharing options...
Scott Posted January 27, 2010 Share Posted January 27, 2010 Maybe the rubber stoppers at either end of the headlights? Quote Link to comment Share on other sites More sharing options...
nevins Posted January 27, 2010 Share Posted January 27, 2010 Maybe the rubber stoppers at either end of the headlights? bit late scott lol. Quote Link to comment Share on other sites More sharing options...
Scott Posted January 27, 2010 Share Posted January 27, 2010 bit late scott lol. Lol, I hope your on the wind up Quote Link to comment Share on other sites More sharing options...
nevins Posted January 27, 2010 Share Posted January 27, 2010 Lol, I hope your on the wind up may be may be not :p I think you need to start a thread about your tent lol Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 27, 2010 Share Posted January 27, 2010 try winding the rubber stoppers by the headlight this might work if the other suggestions dont Quote Link to comment Share on other sites More sharing options...
Lbm Posted January 27, 2010 Share Posted January 27, 2010 Hi all Any ideas on how to get the bonnet flush? Trev Sorry for the hijack, but any ideas on how to make my toilet flush? Rubber grommets or somat? Quote Link to comment Share on other sites More sharing options...
nevins Posted January 27, 2010 Share Posted January 27, 2010 Sorry for the hijack, but any ideas on how to make my toilet flush? Rubber grommets or somat? Quote Link to comment Share on other sites More sharing options...
Scott Posted January 27, 2010 Share Posted January 27, 2010 Sorry for the hijack, but any ideas on how to make my toilet flush? Rubber grommets or somat? Common problem, what does the loo water taste like? Quote Link to comment Share on other sites More sharing options...
nevins Posted January 27, 2010 Share Posted January 27, 2010 does the water spin clock wise or anti clock wise Quote Link to comment Share on other sites More sharing options...
Lbm Posted January 27, 2010 Share Posted January 27, 2010 Common problem, what does the loo water taste like? Mostly pish. But with a surprising and welcome coriander aftertaste. Quote Link to comment Share on other sites More sharing options...
Scott Posted January 28, 2010 Share Posted January 28, 2010 Mostly pish. But with a surprising and welcome coriander aftertaste. Thought as much. When you are so high on drugs that you willingly taste known pishy water it is usually a sure sign that you are pushing up on the flush lever. Try pushing down the way, briskly and firmly. HTH Quote Link to comment Share on other sites More sharing options...
Lbm Posted January 28, 2010 Share Posted January 28, 2010 Thought as much. When you are so high on drugs that you willingly taste known pishy water it is usually a sure sign that you are pushing up on the flush lever. Try pushing down the way, briskly and firmly. HTH Excellent. I have taken your advice and from now on I shall push down on the lever. I've tried it and it has made my toilet flush. Thanks. All that's left to do is finish my bag of smack and then I shall have a go at the toilet seat. It's gone yellow and I'd like to restore it back to original condition. Will I need grommets for this? (Sorry to the OP) Quote Link to comment Share on other sites More sharing options...
