Bonnet help, not quite flush
TrevS
Hi all
Just got my new Supra home and it appears the bonnet isn't sitting quite flush when its closed and sits up a little. I've avoided pressing down on the bonnet and instead tried dropping the bonnet from a little higher to avoid denting/benting it but it still doesn't look quite right.
Any ideas on how to get the bonnet flush?
Trev
Hi all
Trev
try screwing the rubber grommits in/out till the bonnet sits right they are at the front on either side of the engine bay!
oh beaten to it! :tongue:
Mostly pish. But with a surprising and welcome coriander aftertaste.
Thought as much. When you are so high on drugs that you willingly taste known pishy water it is usually a sure sign that you are pushing up on the flush lever.
Try pushing down the way, briskly and firmly.
HTH
HTH
Excellent. I have taken your advice and from now on I shall push down on the lever. I've tried it and it has made my toilet flush. Thanks.
All that's left to do is finish my bag of smack and then I shall have a go at the toilet seat. It's gone yellow and I'd like to restore it back to original condition. Will I need grommets for this? (Sorry to the OP)
