nevins Posted January 29, 2010 Share Posted January 29, 2010 ideally trailor it but if you cant do that just take it easy Link to comment Share on other sites More sharing options...
TrevS Posted January 29, 2010 Author Share Posted January 29, 2010 Theres no way I can trailor it so it might be a case of sticking with the current garage Link to comment Share on other sites More sharing options...
nevins Posted January 29, 2010 Share Posted January 29, 2010 how bad is it sticking have you got a constant groan Link to comment Share on other sites More sharing options...
TrevS Posted January 29, 2010 Author Share Posted January 29, 2010 No, can't even notice it at slow speed and a knocking noise occurs at motorway speeds. Just worried that the garage might have already stripped the brake down and might not drive the same if they refit the disc and pad. Trev Link to comment Share on other sites More sharing options...
nevins Posted January 29, 2010 Share Posted January 29, 2010 so the cars already at a garage, if they say they can do it and its stripped let them have a go at it mate. Link to comment Share on other sites More sharing options...
JamieP Posted January 29, 2010 Share Posted January 29, 2010 If using oem parts there price seems good to me, seems a little harsh to me taking the car away from them after they have done the fault finding. Link to comment Share on other sites More sharing options...
TrevS Posted January 29, 2010 Author Share Posted January 29, 2010 If using oem parts there price seems good to me, seems a little harsh to me taking the car away from them after they have done the fault finding. I am sure they will charge me for finding the fault. Its just they aren't a specialist so I was concerned that they might charge me too much for the parts. Not concerned about labour charges as I imagine they will be the same where ever. Ill get them to break down the cost of the parts and labour and post up here to see how they compare to others on cost. Link to comment Share on other sites More sharing options...
nevins Posted January 29, 2010 Share Posted January 29, 2010 iirc caliper repair kit is in the region of £37 Link to comment Share on other sites More sharing options...
TrevS Posted January 29, 2010 Author Share Posted January 29, 2010 Right. My local garage is fitting an exchange unit caliper and ferodo discs and pads on Monday. They have estimated it to be £380+VAT. Just want to check that I should be paying this much for replacement parts and those discs? Trev Link to comment Share on other sites More sharing options...
Dnk Posted January 29, 2010 Share Posted January 29, 2010 i posted a price list for you and with a cheaper labour rate labour rates vary massively from garage to garage. Regarding the parts why dont you order every thing yourself via Steve Manley and save a few ££'s Link to comment Share on other sites More sharing options...
TrevS Posted January 29, 2010 Author Share Posted January 29, 2010 If its only saving a few quid then its probably not worth it. I just wanted to get peoples opinions on the price based on the fact they are ferodo discs and not Toyota OEM. Link to comment Share on other sites More sharing options...
AlexM Posted January 29, 2010 Share Posted January 29, 2010 Approx £260 in parts My local garage is fitting an exchange unit caliper and ferodo discs and pads on Monday. They have estimated it to be £380+VAT If you consider the prices Dunk checked for you, you're paying up to £185 in labour there. That's one hell of a lot for a few hours work. If its only saving a few quid then its probably not worth it. I just wanted to get peoples opinions on the price based on the fact they are ferodo discs and not Toyota OEM. Ferodo discs aren't going to give you any benefit, Toyota OEM are perfectly fine. Personally I would get the caliper refurbished, or buy a replacement on the for sale forum here. Get some new OEM discs or secondhand ones, a full set of Chris Wilson's Fast Road pads, and some quality fluid. Either pay someone else to fit all that or do it yourself (it's very easy!). I picked up a full set of calipers, discs and pads on here for Link to comment Share on other sites More sharing options...
Dnk Posted January 29, 2010 Share Posted January 29, 2010 (edited) I have just called a Ferodo supplier and they quoted me £115 inc vat for front discs and pads for your car !!! The ferodo supplier has just called me back and said there are 2 types it could be and the other is £258 inc vat, dependant on wheel size ?? i guess this could be uk spec perhaps ? Personally i would fit Toyota parts and refurb the caliper, it doesnt take long to do, to give you an idea if you gave me the caliper i could have it done in under an hour no problem with new seals and pistons fitted !! While your doing this i strongly recomend you check the other seals on the rest of the calipers, they also will be on the verge of doing the same if the outer seals havent been changed !! Edited January 29, 2010 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
nevins Posted January 29, 2010 Share Posted January 29, 2010 I would go with what alex has said you can always speak to CW and he will help you out Link to comment Share on other sites More sharing options...
TrevS Posted January 29, 2010 Author Share Posted January 29, 2010 Too late now, the garage has been given the green light and are expecting the parts on Monday. Link to comment Share on other sites More sharing options...
TrevS Posted January 29, 2010 Author Share Posted January 29, 2010 I have just called a Ferodo supplier and they quoted me £115 inc vat for front discs and pads for your car !!! Could you possibly order some for me from there if I call my garage and ask them to cancel the order on the discs and pads? Trev Link to comment Share on other sites More sharing options...
Dnk Posted January 29, 2010 Share Posted January 29, 2010 This was just a garage i called off the Ferodo's website and to be honest i'd rather not get involved as i dont know them in the slightest. Heres there website http://www.ferodo.co.uk/ferodo_home/car.html There is a map of the country you can use to find your nearest supplier. The one i called was in Wolverhapmton, A & E services and their tel is 0121 557 1977 I can assist you with o/e parts and recomend Steve Manley at Inchcape Toyota in Oxford who i know very well. 01865 291 333, i called him earlier to get the prices i posted here for you. Link to comment Share on other sites More sharing options...
TrevS Posted January 29, 2010 Author Share Posted January 29, 2010 This was just a garage i called off the Ferodo's website and to be honest i'd rather not get involved as i dont know them in the slightest. Heres there website http://www.ferodo.co.uk/ferodo_home/car.html There is a map of the country you can use to find your nearest supplier. The one i called was in Wolverhapmton, A & E services and their tel is 0121 557 1977 I can assist you with o/e parts and recomend Steve Manley at Inchcape Toyota in Oxford who i know very well. 01865 291 333, i called him earlier to get the prices i posted here for you. Thanks I've tried ringing the closest garage possible and they are going to get me a quote on the parts so ill keep you posted Link to comment Share on other sites More sharing options...
TrevS Posted January 29, 2010 Author Share Posted January 29, 2010 Right one last question. What size are the discs? I am speaking to a supplier that needs to know before he can give me a quote. Cheers Trev Link to comment Share on other sites More sharing options...
TrevS Posted January 29, 2010 Author Share Posted January 29, 2010 Apologies I am back again. I've got the garage to break down the quote and they are saying its the replacement caliper thats going to cost the most money. Pads £52.14 Discs £97.70 Labour £110.45 Total £259.69 However with the caliper on top they have quoted £446.50 so they are charging me £186.81 for the caliper which seems like a lot. Should I go for a used caliper? Silverstone motors have said they have some in stock and Chris W also thinks he might have some. Trev Link to comment Share on other sites More sharing options...
Scott Posted January 29, 2010 Share Posted January 29, 2010 Apologies I am back again. I've got the garage to break down the quote and they are saying its the replacement caliper thats going to cost the most money. Pads £52.14 Discs £97.70 Labour £110.45 Total £259.69 However with the caliper on top they have quoted £446.50 so they are charging me £186.81 for the caliper which seems like a lot. Should I go for a used caliper? Silverstone motors have said they have some in stock and Chris W also thinks he might have some. Trev They are being lazy mate, they don't want to go to the hassle of stripping the caliper. This means that they haven't even done so, they have just put the car on a ramp and span the wheel. Take it to CW, get his 2nd hand parts and be done with it. You can then sell what you have on here. What is wrong with your discs by the way? Seems a bit excessive that you need 2 new discs and 4 new pads for 1 sticking piston. Whoever you have left it with are going to rip you off, they aren't going to see the benefit of a lot of money but you will have the diss-service of paying for their lazyness. Link to comment Share on other sites More sharing options...
TrevS Posted January 29, 2010 Author Share Posted January 29, 2010 They are being lazy mate, they don't want to go to the hassle of stripping the caliper. This means that they haven't even done so, they have just put the car on a ramp and span the wheel. Take it to CW, get his 2nd hand parts and be done with it. You can then sell what you have on here. What is wrong with your discs by the way? Seems a bit excessive that you need 2 new discs and 4 new pads for 1 sticking piston. Whoever you have left it with are going to rip you off, they aren't going to see the benefit of a lot of money but you will have the diss-service of paying for their lazyness. They said the drivers disc was very hot and couldn't gaurantee it hadn't warped and that the discs come in pairs do they'd replace both. Link to comment Share on other sites More sharing options...
Scott Posted January 29, 2010 Share Posted January 29, 2010 They said the drivers disc was very hot and couldn't gaurantee it hadn't warped and that the discs come in pairs do they'd replace both. If I was replacing 1 disc I would indeed replace both. I would be checking the disc to make sure it was fooked before replacing it though. If it is warped slightly a skim will sort that right out and you would have near enough shiney new discs. All you need to do is check the thickness before you start to see if it is worthwhile. Most machine shops will do it for buttons. In my eyes what you are proposing is a waste of money, I don't mind spending money on things but I hate to see it wasted. Oh, what is wrong with the pads? Have the worn right down due to the sticky caliper? It seems to me you noticed the problem fairly early. I know that pads can wear down quick with a sticky caliper but I wouldn't rule them out just yet. Link to comment Share on other sites More sharing options...
Dnk Posted January 29, 2010 Share Posted January 29, 2010 (edited) Thats a joke mate and your garage are obviously just part changers, £187 is approx the cost of a brand new caliper from Toyota !! Your caliper could be fixed and the other side fitted with new seals for a lot less than that. Are they fitting a brand new caliper ? Edited January 29, 2010 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
AlexM Posted January 29, 2010 Share Posted January 29, 2010 Have you been over to see if they've even taken the caliper off the car? Link to comment Share on other sites More sharing options...
