Toyo 888's 285 30 18
Terminator
SOLD For sale on pair of used Toyo R888's tread depth 2.5mm to 3.5mm used on the track. Tread 6mm when new. Still plenty of tread for a couple of track days. Open to sensible offers. Pick up preferred, but could arrange courier.
Any reasonable offer considered.
Pic to follow, when it is daylight.
Around £190 each. They are not bad in the wet, due to their wide groves they shed water at lower tread depth than standard tires. If used as track or drag tires they will be good down to slicks and beyond. If no one wants, them I will abuse them in the summer.
Hmmm good idea. i need them for the road though. How is the grip in the dry, im spinning up everything ive tried up to 120mph including bridgestones, conti's, michellin, ventura....
They grip well in the winter but below 5 degrees, no summer tire will be much good. The R888's are not designed to be an all weather tire. I use Race Logic all the time in winter so I never get wheel spin, which make my tires last longer:d In summer when it is mostly switched off turn RL off I can spin the 888's in 4th:innocent:
