No brake lights, front dim lights or central locking.
mr veilside
i had the exact same problem last weekedn mate, all it was is a earth in the boot. ts located right ant the abck in the midle under the rear trim, you cant miss it.
All i did was take it of, clean with wd40 and it worked. I will warn you though a few mins after this a wiring loom decided to melt, but that is what caused the prob on mine.
T
Found two blown fuses, one for the tail lights and one for the radio. Where is the fuse for the front fogs located? I looked at the under bonnet fuse box panel and saw that it points to a big square relay for the fogs but couldnt see a fuse for it.
I couldnt get this relay off either.
How do you remove the relays in the fuse box as i want to test with another relay to see if the lights work.
Edited by mr veilside (see edit history)
