FRONT Jap spec turbo for rebuilding
Chris Wilson
Looking for a FRONT none VVTi, Jap spec stock turbo with no cracks in the turbine housing wastegate seat, or anywhere else. Just a turbine housing is fine, or will buy a full turbo. Needed for rebuilding, I have a few cores, but all have cracked seats and I'd rather not have them welded. Thanks. The FRONT turbos have SHORTER turbine housings than the rears. I can probably ID off a decent photo. Cheers.
Guest SupraGTE
i will have a look when i get home, have 3o f front turbos jspec, do you see the crack the good? any picture of the crack so know what to look for,
btw what is the rebuild cost for j spec?
cheers
Marty is sending one over from Ireland, I think I should now be sorted, it's been a nightmare, T Dynamics have about seven turbos over at their place, trying to find a front one without a wastegate crack. It seems these things are now of an age where heat cycling has taken it's toll, just like RX-7 front turbos.
Thanks for the offer, don't put yourself out for now Darren, please. Appreciate the time.
