thinking about selling the sup but whats it worth
phat supra
as the above thinking of selling my sup tt 6spd rz 93 full bpu white an save in up for a single sup but not sure yet what am going to do just wanted to no how much they are going for at the mo. mine has done 133000 kph always looked after and serviced regularly valve stem oil seals done about a year ago. 10 months mot & 4 tax
some of the spec
full bpu
blitz nuf spec back box
blitz nuf spec center pipe & 2nd de cat
envy 1st de cat
walbro fuel pump
denso plugs
fmic
syntec fuel pressure reg
greddy boost gage
hks cam pullys
hks cam belt
apexi induction kit
hks f-con piggy back ecug
g3 disks on the front endless pads
stock on rear
tien super street suspension
kei d1 18inc wheels 8.5 f 9.5 r
bomex front bumper
bomex side skirts
trial rear
+ other things that i can’t remember at the mo
thanks for your help lee
Could you not single your car?
Seems from that spec list you need a turbo kit and some bigger injectors.....still be cheaper than selling yours and saving the difference:)
I would definatly put the single on that car and not sell, look for a secondhand kit and some decent injectors, the rest is there.
am not to sure mate could put another 10 k in to it to go single but could probaly pick one up done for about 13 to 14 k just tryin to see wich is the best way to go about it really thanks
I agree with dude here, you already have most of the supporting mods in place for a single (the expensive part of converting!).
Just needs some injectors and a single kit.
This is one rare time it makes more sense to do the conversion than sell and buy one already done.
Personally I would always prefer to convert a car I know rather than buy a single turbo, unless I was absolutely sure the car I was buying was a good one and properly converted.
Yes you may spend more converting your own car, but you will have the peace of mind that it is done right. Unless you know the history of the single turbo car and all the parts fitted to it, then you could be buying an unknown quantity and find you have to throw more money at it to get it to run right.
Where are you getting 10K from dude, a BL turbo kit with 4" DP/MP and a billet wheel turbo is around $4200 fuel rail and injectors prob $600 plus fitting and a bit of mapping.
+ new ecu £1000 + all the bits i need to fit and mapping
+ new clutch only stock at the mo
+ a uk brake kit
and a few othere bits so think all done may get away with 6 to 7 k maybe not 100% sure never done one thanks
+ a uk brake kit
Solaris ecu £1400
Bits needed + mapping £800ish
RPS stage 3 clutch £500-600
Brakes if you go for what Paul Whiffins doing on the K sport big brake setup a full set is about £2000
So about 5k then a bit more for things that are forgotten and over looked.
Im going through it all mate spent about 5k and still need a turbo kit yet then mapping and labour.
Sometimes I think is it all worth it and should I sell all the parts leave my supra BPU and get a Celica GT4 I want.
you already have a decent ecu for the job fella ;)
i think the ecu is called somethin like pfc con or some thin like that an looks older than the car so unless am wrong i think ths ecu piggy back is for the fuel only sure nic will be able to tell us
thanks for you help
