Decat doing my head in
pistonbroke
Some of you may be aware that my car failed it's MOT the emissions. So I took the car away to put the second CAT in. I've just found out that my second decat rear 2 bolts are too big. They are 17" nut and bolt which have no gap between the side of the bolt/nut and the actual pipe. I've just done this to a spanner trying to get the buggers off.
Now I'm stuck :(
Ring spanner and a hammer, soak the threads in WD40 or a penetrating fluid first. You may need to get a socket on a bar on them to shift them.
Thats the problem though, there's not even enough room for a ring spanner.
And dont use Tesco's spanners lol
All my stuff is snap on :p
Is it worth going to a import friendly MOT centre? Seems like a massive amount of work, just to take it off a few moments later. Plus no guarantee it will pass its emission on one cat being on.
Mate, if I knew one, I'd be going there. The one I took it too was supposed to be BPU freindly, but he went all legit on me when I got there.
:D Thats a bit drastic.
I was being serious :)
If you can't get a socket or ring spanner on them you could spend hours swearing and scraping your knuckles trying to shift them.
Alternatively, if you can get access, you could spend 2 minutes grinding the buggers off.
You'll have to replace the bolts anyway by the sounds of it. I know which option I'd choose :)
  • 2 months later...
I fitted my decats last weekend and had the same problem but from the 2nd decat to the back section, i just removed the bolts to the second decat removed the exhaust and used an angle grinder to remove the bolts.
As long as you cut at the back of the flange you wont damage them. Also invest in some plusgas or the freeze your nuts off sprays, they are amazing.
