nevins Posted January 25, 2010 Share Posted January 25, 2010 great minds think alike lol Link to comment Share on other sites More sharing options...
Scott Posted January 25, 2010 Share Posted January 25, 2010 This forum is going downhill Link to comment Share on other sites More sharing options...
Guest RWD-passion Posted January 25, 2010 Share Posted January 25, 2010 Just got an email from a close friend what where doing and here it is: Engine/Intake/Exhaust: Rod Millen downpipe Unknown aftermarket exhaust (already on Supra when I bought it) HKS SSQV BOV (OEM location) Max Air Box with K&N filter Greddy oil filter relocation kit Various TTC dress up items Cooling: Fluidyne Radiator Greddy 3 row intercooler Powerhouse Racing polished upper radiator pipe Electronics: TRD 10k Tach Greddy Boost controller Greddy turbo timer Greddy 60mm Boost gauge Greddy 60mm A/F gauge (narrowband FTL) Greddy Boost Cut Controller Fields Harness Engine: HKS GT-2835 Twin Turbo Kit which consists of: GT2835 Dual Ball Bearing Turbo x 2(0.73 A/R) 50mm S/S Racing Wastegate x 2 (with upgraded 1.3 Bar wastegate springs) 2 piece Equal Length S/S Exhaust Manifold (Jet Hot Ceramic Coated-2000 series) HKS 3.4 Stroker kit which consists of: HKS Forged and Balanced +8mm Long-Throw Crankshaft, HKS “H” Beam Forged Connecting Rods, HKS Nickel Plated and Forged 87 mm Pistons, HKS Piston Rings and Wrist Pins HKS 264 Intake and Exhaust Cams HKS Adjustable Cam Gears HKS Timing Belt HKS Metal Head Gasket 1.2 mm HKS SSQV BOV (adjustable version) Head ported and polished Ferrea Intake and Exhaust Alloy valves Ferrea Valve Seat Locators Ferrea Valve Seals Ferrea Valve Locks Ferrea Valve Guides Ferrea Titanium Retainers Ferrea Dual Valve Springs Powerhouse Racing Billet Timing Belt Tensioner Bracket Powerhouse Racing Engine Breather kit ATI Super Damper Crank Pulley Unorthodox Racing lightweight Alternator pulley (stock size) Unorthodox Racing lightweight Water Pump pulley (stock size) Unorthodox Racing lightweight Power Steering pulley (stock size) Twins Turbo Thermostat Rotating Plate TRD engine mounts ARP Head Studs Complete Rebuild Gasket kit Water Pump Oil Pump Oil Pickup/Strain Clutch/Drivetrain: OS Giken: R3C Triple Plate Clutch TRD LSD TRD ss clutch line TRD tranny mount Intake/Exhaust: Veilside Intake Manifold with 100mm Throttle Body (extremely rare) HKS 102mm Titanium Racing Exhaust Blitz midpipe SP Engineering custom aluminum charge piping Fuel: HKS Fuel Pressure Regulator with custom NOS fuel pressure gauge Veilside Billet Fuel Rail Blitz 1000cc Top Feed Injectors x 6 TTC Triple Fuel Pump Hangar Dual OEM fuel pumps SP Engineering custom-made fuel system Cooling: Fluidyne Radiator Greddy 4 row intercooler (replaced 3 row) PHR polished upper radiator pipe Greddy 16 row oil cooler with oil filter relocation kit HKS Power steering cooler Titek CF radiator cooling plate TRD thermostat Electronics/Interior: HKS V-pro Engine Management System (version 3.24) HKS A/F knock amp with dual band readout (2 wideband O2 sensors, one for each turbo) HKS Mixture Controller (control mounted in armrest) HKS DLI-2 Twin Power Ignition Amplifier HKS EVC VI boost controller HKS Turbo Timer-Type 1 DEFI Advance CR control unit DEFI Advance CR 60mm Boost gauge DEFI Advance CR 60mm Oil pressure gauge DEFI Advance CR 60mm Oil Temp gauge DEFI Advance CR 60mm Water Temp gauge SP Engineering Dual Intake Temperature Gauge Titek Carbon Fiber triple gauge pod Racelogic Traction Control (control mounted in armrest) C’s Short Throw Shifter TRD steering wheel TRD 10k Tach Brakes: Brembo 6 piston MonoBlock 14.0” Big Brake Kit (front) Brembo 4 piston 13.58” Big Brake Kit (rear) Rims: To be determined Suspension/Handling: HKS Type II Hipermax Coilovers Sparco Harness Bar Titan Motorsports front and rear anti-sway bars JIC tie rods Cusco Carbon Fiber rear strut tower bar Do-Luck aluminum floor assist bars (on order) Racelogic Traction Control Stereo/Battery: Eclipse 6620 double din w/ navigation (2) Braille B14115C Carbon Fiber batteries (2) Braille B14115C battery mounts 4 gauge wiring Engine Dress up: Polishing done by Tony Brock Titek CF spark plug cover Titek CF fuse box cover Titek CF radiator cooling plate TRD oil cap TTC polished idler pulley TTC Billet Aluminum shock arm TTC Brake and Power Steering cap TTC Clutch Master Cylinder cap TTC Windshield Washer cap TTC Oil dipstick Polished parts: Valve covers with custom -12AN fittings for breather tank Veilside Throttle body and all associated hardware Veilside fuel rail (2) HKS 2835 turbo housings (2) HKS turbo heat shields Etc To be finalized….. Fluids: To be determined Anything you can put input on to very pleasing Cheers RWD-passion Link to comment Share on other sites More sharing options...
creativename Posted January 25, 2010 Share Posted January 25, 2010 I think you guys are being a bit harsh.........the amount of the money he earns he could easily afford to import this from down under To the OP, have you considered some over night parts from Japan? If you need some help I could ask my friend Harry to hook you up. Link to comment Share on other sites More sharing options...
nevins Posted January 25, 2010 Share Posted January 25, 2010 people should think before posting as if they found it that easy others will too Link to comment Share on other sites More sharing options...
JustGav Posted January 25, 2010 Share Posted January 25, 2010 And, how exactly are you going to fit the triple plate to an auto? hmmmm *sniff* Price: $20.900 Colour: White Year: 1998 Fuel Type: Petrol Capacity: 1998 Gears: 4 Gearbox: Auto Odometer: 60,000 Drive Type: RWD OS Giken: R3C Triple Plate Clutch Which version of field harness are you intending to use, the 12v+ or the 36v+(vvti edition)? Link to comment Share on other sites More sharing options...
Scott Posted January 25, 2010 Share Posted January 25, 2010 I think you guys are being a bit harsh.........the amount of the money he earns he could easily afford to import this from down under To the OP, have you considered some over night parts from Japan? If you need some help I could ask my friend Harry to hook you up. I did think of that, but the fact he called a 1998 auto VVTi supra a 1996 manual model kinda gives it away. Link to comment Share on other sites More sharing options...
nevins Posted January 25, 2010 Share Posted January 25, 2010 RWD check the post as I think you have something to tell everyone Link to comment Share on other sites More sharing options...
Scott Posted January 25, 2010 Share Posted January 25, 2010 Just got an email from a close friend what where doing and here it is: Engine/Intake/Exhaust: Rod Millen downpipe Unknown aftermarket exhaust (already on Supra when I bought it) HKS SSQV BOV (OEM location) Max Air Box with K&N filter Greddy oil filter relocation kit Various TTC dress up items Cooling: Fluidyne Radiator Greddy 3 row intercooler Powerhouse Racing polished upper radiator pipe Electronics: TRD 10k Tach Greddy Boost controller Greddy turbo timer Greddy 60mm Boost gauge Greddy 60mm A/F gauge (narrowband FTL) Greddy Boost Cut Controller Fields Harness Engine: HKS GT-2835 Twin Turbo Kit which consists of: GT2835 Dual Ball Bearing Turbo x 2(0.73 A/R) 50mm S/S Racing Wastegate x 2 (with upgraded 1.3 Bar wastegate springs) 2 piece Equal Length S/S Exhaust Manifold (Jet Hot Ceramic Coated-2000 series) HKS 3.4 Stroker kit which consists of: HKS Forged and Balanced +8mm Long-Throw Crankshaft, HKS “H” Beam Forged Connecting Rods, HKS Nickel Plated and Forged 87 mm Pistons, HKS Piston Rings and Wrist Pins HKS 264 Intake and Exhaust Cams HKS Adjustable Cam Gears HKS Timing Belt HKS Metal Head Gasket 1.2 mm HKS SSQV BOV (adjustable version) Head ported and polished Ferrea Intake and Exhaust Alloy valves Ferrea Valve Seat Locators Ferrea Valve Seals Ferrea Valve Locks Ferrea Valve Guides Ferrea Titanium Retainers Ferrea Dual Valve Springs Powerhouse Racing Billet Timing Belt Tensioner Bracket Powerhouse Racing Engine Breather kit ATI Super Damper Crank Pulley Unorthodox Racing lightweight Alternator pulley (stock size) Unorthodox Racing lightweight Water Pump pulley (stock size) Unorthodox Racing lightweight Power Steering pulley (stock size) Twins Turbo Thermostat Rotating Plate TRD engine mounts ARP Head Studs Complete Rebuild Gasket kit Water Pump Oil Pump Oil Pickup/Strain Clutch/Drivetrain: OS Giken: R3C Triple Plate Clutch TRD LSD TRD ss clutch line TRD tranny mount Intake/Exhaust: Veilside Intake Manifold with 100mm Throttle Body (extremely rare) HKS 102mm Titanium Racing Exhaust Blitz midpipe SP Engineering custom aluminum charge piping Fuel: HKS Fuel Pressure Regulator with custom NOS fuel pressure gauge Veilside Billet Fuel Rail Blitz 1000cc Top Feed Injectors x 6 TTC Triple Fuel Pump Hangar Dual OEM fuel pumps SP Engineering custom-made fuel system Cooling: Fluidyne Radiator Greddy 4 row intercooler (replaced 3 row) PHR polished upper radiator pipe Greddy 16 row oil cooler with oil filter relocation kit HKS Power steering cooler Titek CF radiator cooling plate TRD thermostat Electronics/Interior: HKS V-pro Engine Management System (version 3.24) HKS A/F knock amp with dual band readout (2 wideband O2 sensors, one for each turbo) HKS Mixture Controller (control mounted in armrest) HKS DLI-2 Twin Power Ignition Amplifier HKS EVC VI boost controller HKS Turbo Timer-Type 1 DEFI Advance CR control unit DEFI Advance CR 60mm Boost gauge DEFI Advance CR 60mm Oil pressure gauge DEFI Advance CR 60mm Oil Temp gauge DEFI Advance CR 60mm Water Temp gauge SP Engineering Dual Intake Temperature Gauge Titek Carbon Fiber triple gauge pod Racelogic Traction Control (control mounted in armrest) C’s Short Throw Shifter TRD steering wheel TRD 10k Tach Brakes: Brembo 6 piston MonoBlock 14.0” Big Brake Kit (front) Brembo 4 piston 13.58” Big Brake Kit (rear) Rims: To be determined Suspension/Handling: HKS Type II Hipermax Coilovers Sparco Harness Bar Titan Motorsports front and rear anti-sway bars JIC tie rods Cusco Carbon Fiber rear strut tower bar Do-Luck aluminum floor assist bars (on order) Racelogic Traction Control Stereo/Battery: Eclipse 6620 double din w/ navigation (2) Braille B14115C Carbon Fiber batteries (2) Braille B14115C battery mounts 4 gauge wiring Engine Dress up: Polishing done by Tony Brock Titek CF spark plug cover Titek CF fuse box cover Titek CF radiator cooling plate TRD oil cap TTC polished idler pulley TTC Billet Aluminum shock arm TTC Brake and Power Steering cap TTC Clutch Master Cylinder cap TTC Windshield Washer cap TTC Oil dipstick Polished parts: Valve covers with custom -12AN fittings for breather tank Veilside Throttle body and all associated hardware Veilside fuel rail (2) HKS 2835 turbo housings (2) HKS turbo heat shields Etc To be finalized….. Fluids: To be determined Anything you can put input on to very pleasing Cheers RWD-passion http://www.sp-power.com/category/project-cars/ Is there a pool going on this kids age yet? I'm in for a fiver on 16 Link to comment Share on other sites More sharing options...
JustGav Posted January 25, 2010 Share Posted January 25, 2010 I believe the google image he may be looking for is...... http://www.myspaceantics.com/images/myspace-graphics/funny-pictures/owned-subaru.JPG Link to comment Share on other sites More sharing options...
creativename Posted January 25, 2010 Share Posted January 25, 2010 Have you thought of dumping the 2jz and using a galo 24? I no that's a bit extreme and the galo 12 is half the weight, but with your budget why not go the whole hog.......... Link to comment Share on other sites More sharing options...
Scott Posted January 25, 2010 Share Posted January 25, 2010 I believe the google image he may be looking for is...... http://www.myspaceantics.com/images/myspace-graphics/funny-pictures/owned-subaru.JPG Either that or... Afterall, he is going for gold. Link to comment Share on other sites More sharing options...
Guest RWD-passion Posted January 25, 2010 Share Posted January 25, 2010 Well guys believe what you like im off till tomorrow now see ill chat with you guys then, but for those who are not simple minded WATCH THIS SPACE !!!. Cheers RWD-passion Link to comment Share on other sites More sharing options...
nevins Posted January 25, 2010 Share Posted January 25, 2010 just found where he copied it from, word for word http://forums.maxima.org/members-rides/600934-wizard-s-stroked-750hp-supra-build-tons-pics-updated-frequently.html Link to comment Share on other sites More sharing options...
Scott Posted January 25, 2010 Share Posted January 25, 2010 Well guys believe what you like im off till tomorrow now see ill chat with you guys then, but for those who are not simple minded WATCH THIS SPACE !!!. Cheers RWD-passion Between your ears? Link to comment Share on other sites More sharing options...
JustGav Posted January 25, 2010 Share Posted January 25, 2010 Well guys believe what you like im off till tomorrow now see ill chat with you guys then, but for those who are not simple minded WATCH THIS SPACE !!!. Cheers RWD-passion Bed time then, you might be late for school otherwise Link to comment Share on other sites More sharing options...
creativename Posted January 25, 2010 Share Posted January 25, 2010 What time is your first break? Can you let me know in advance so I can make sure im online. Also do you not think your dad's laptop is best used for searching for porn? Link to comment Share on other sites More sharing options...
JustGav Posted January 25, 2010 Share Posted January 25, 2010 just found where he copied it from, word for word http://forums.maxima.org/members-rides/600934-wizard-s-stroked-750hp-supra-build-tons-pics-updated-frequently.html Send him the link, he may be flattered by someone doing an identical build. Link to comment Share on other sites More sharing options...
j_jza80 Posted January 25, 2010 Share Posted January 25, 2010 So you're going to get someone from just outside Kansas to do your engine polishing... Welcome to the forum you old trickster you! Link to comment Share on other sites More sharing options...
nevins Posted January 25, 2010 Share Posted January 25, 2010 look mate if you want I will email the owner of the car and get him to tell you that you are full of it. No offence but wipe your lip your talking shit. Link to comment Share on other sites More sharing options...
S44M KT Posted January 25, 2010 Share Posted January 25, 2010 Ibtl Link to comment Share on other sites More sharing options...
JustGav Posted January 25, 2010 Share Posted January 25, 2010 Wonder if the supra has changed from this one? http://www.mkivsupra.net/vbb/showpost.php?p=2639084&postcount=1 Link to comment Share on other sites More sharing options...
creativename Posted January 25, 2010 Share Posted January 25, 2010 Has anyone else had a friend request from this troll? Link to comment Share on other sites More sharing options...
JustGav Posted January 25, 2010 Share Posted January 25, 2010 Ibtl Not yet, I am going to move it to off topic. Link to comment Share on other sites More sharing options...
Scott Posted January 25, 2010 Share Posted January 25, 2010 IP Match Gav? Link to comment Share on other sites More sharing options...
