max21 Posted March 7, 2010 Author Share Posted March 7, 2010 Hi Ian, I have had this problem looked at by an Auto-sparky and he says the alternator is faulty hence the reason I don't get any management lights as there is "continuity between the alternator and the battery" [not that I know whnat this means]. Please can you tell me what exactly I am looking for around the picture, i.e. if the cable is still attached, is this a good sign, or better still what is the bad sign I am looking for. and if I need to get a replacement alternator or a cable, do you know where I can get one without being robbed? Thanks for your help. Regards, Found a pic. I've arrowed in yellow where the strap attaches. Should be fairly reachable. It's probably a good idea not to let it touch any metal or bodywork or anything -Ian Link to comment Share on other sites More sharing options...
D8MOA Posted March 7, 2010 Share Posted March 7, 2010 when you charged the battery you didnt charge it backwards did you? i once brought a rover (dont laugh) and the owner gave me a battery he had charged but every time i put the battery on it would spark and the cables would get hot... i then put on a battery i had and all was fine!! i only assumed it was a duff battery or he had charged it the wrong way round from dead flat (dont no if that can actually be done or not as never tried) Link to comment Share on other sites More sharing options...
colmcork Posted March 29, 2010 Share Posted March 29, 2010 Right, the part number for 120 amp fuse is; 90982-08271. Over here it costs 10.67 euro. Hope this helps mate Link to comment Share on other sites More sharing options...
