Supra won't start, No Engine Management lights
max21
Hello,
please has anyone experienced this sort of issue on the RZ-TT?
My car had been stationary through out the cold/snow spell and prior to that, it was all ok. Now, it won't start, the starter solenoid/motor does not turn, the engine managment lights do not come on, the 120A alternator fuse is gapped, the 20A radiator fuse is gapped as well as the AMS-30A fuse. Please has anyone a clue on how I can restore happiness to my Supra, especially, how can I get the broken 120A alternator fuse out and where I can source a replacement?
By the way, I had previously re-charged the battery and used a booster, but no joy what-so-ever, so any positive suggestion would be appreciated, is there anyone close to High Wycombe, bucks on this forum?
Thanks for reading,................... :Pling:
[ANGRY][/ANGRY]
/vbb/images/smilies/bbcode_sad.gif
/vbb/images/smilies/bbcode_oops.gif
Have you tried a New BATTERY??
Reason i said this i had same problem, turned out to be a duff battery(cell) in it, got my self down to halfords and got a new one, job done
The battery is virtualy new, I replaced it last Autumn. But at lease a duff battery should allow the managemnet lights to come on,...............
Cold weather played havoc with mine dude, i had NO lights on, and no click from starter motor.
Try a new battery, rules one option out...
Sure, I'll do that. Please do you have any idea on how I could replace the 120A alternator fuse?
Hi there i am a newbie here. I have just replaced my 120 amp alternator fuse. You need to undo the 3 bolts holding in the entire fusebox. Lift it up, turn it over and you will see 2 bolts holding in alternator fuse. Undo these, whip out old fuse and then replace with new one. I will dig out the part number for you in a tick. Had to get mine from Toyota. Hope this is some help.
No the car was only jump started after the recharged battery failed to make any difference. It appears there is some sort of short circuit somewhere in the starting system as even without the 120 amp fuse, when the battery terminals are connected, the management lights don't come on and it keeps blowing the 20Amp Radiator fuse [ANGRY][/ANGRY]
Correct me if I'm wrong but I thought the 120a fuse is there to protect other components from power surges often caused by jump starting, if your unlucky it can also fry the igniter and worse still the ecu.
I would get a multimeter and make sure your battery is giving you a good reading, around 12-13v.
Also make sure the battery terminals are connected nice and tight.
Can you rule out your alarm/immobiliser too?
Update, I don't think it is a jump start or battery issue as today I put new fuses (120 Fuse link and 30amp AMS fuse) and a new battery and immediately the terminals were connected, there was a little crackle and pop went both fuses. So Maybe there is a Short somewhere. Please does anyone know what the AMS fuse does or who on this forum can help diagnose the problem?
Thanks, now I'll go a buy shares in a fuse making company
Regards,
H
I know this is a silly question but it is often the silly ones that lead to the correct answers.
The battery isn't in the wrong way round is it? Are you positive you are connecting the right terminals to the right cables? The supra has a back to front battery.
It's not going to be the ECU, that's way down the chain. The circuit path is Battery -> 120A Alt fuse, with a branch off to 30A AM2. So not the most difficult circuit path to follow.
Disconnect the big strap-ring connection on the alternator and try again - I think there is a regulator in them that can go wrong and cause problems like this.
-Ian
-Ian
Thanks Ian, forgive my ignorance, what does the AM2 30amp fuse do and also what does the "big strap-ring" connection look like?
Thanks.
H
AM2 leads to the ignition switch.
A big strap. With a ring on the end :)
Look at the alternator, it'll be quite apparent, there are two things connected to it, one's a normal 3-wire plug, the other is a thick cable that has the ring end hooked over a stud with a nut on top holding it in place.
Thanks Mate, I see some light,...................
sounds like someone may have jumped it the wrong way around...? ive had a few calls from customers who have done the same thing with the same fuses blown.
When you say jumped it the wrong way round, Do you mean put the leads on the wrong way? Ie negative onto plus? Would this cause fuses to blow?
