JustGav Posted January 23, 2010 Share Posted January 23, 2010 It sounds very much like you aren't passing the chroma aspect of Svideo and only the lumina pin. You are better off using a 4pin to 4pin svideo lead. Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 It sounds very much like you aren't passing the chroma aspect of Svideo and only the lumina pin. You are better off using a 4pin to 4pin svideo lead. Sound i'll get one of those. This is just gonna drive me mad lol. Link to comment Share on other sites More sharing options...
Digsy Posted January 23, 2010 Share Posted January 23, 2010 This might be worth a read, but as mentioned above the 4-pin to 4-pin lead should work. The bit about 7-pin plugs is down the page a bit. You won't get any sound though. S-video is video only. Plus it will look absolutely rubbish for anything other than watching videos full-screen. Link to comment Share on other sites More sharing options...
Suprab1 Posted January 24, 2010 Author Share Posted January 24, 2010 Hi all just to let you know problem solved. All i had to do is right click on desktop, go to properties, Settings, Advanced, Intel graphics media accelerator driver for mobile, Graphics properties, Select the duel mode and apply then sat back and wached the film. Thanx for all your help. I would have just given up without you cheers. Ps had to use phono leads for sound. Link to comment Share on other sites More sharing options...
ivan Posted January 24, 2010 Share Posted January 24, 2010 I suspect that's what JustGav meant when he said check the desktop is enabled. Link to comment Share on other sites More sharing options...
