Suprab1 Posted January 23, 2010 Share Posted January 23, 2010 Hi all just wondering about connecting my laptop (Dell inspiron 6400) to a tv. I got a s-video lead, plugged it all up but it just flashes on the tv for a second. The lad in the shop said my computer must not be able to connect to the tv. I was just looking at the lead and it has 4 pins my computer has 7. Can this be whats wrong as i'm sure it doesn't have an s-video socket in it for a laugh cheers. Link to comment Share on other sites More sharing options...
JustGav Posted January 23, 2010 Share Posted January 23, 2010 Hi all just wondering about connecting my laptop (Dell inspiron 6400) to a tv. I got a s-video lead, plugged it all up but it just flashes on the tv for a second. The lad in the shop said my computer must not be able to connect to the tv. I was just looking at the lead and it has 4 pins my computer has 7. Can this be whats wrong as i'm sure it doesn't have an s-video socket in it for a laugh cheers. 7 pin? sure that isn't the ps2 ouput from external mouse and keyboard. Check the manual Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 7 pin? sure that isn't the ps2 ouput from external mouse and keyboard. Check the manual No checked manual and it says 'S-video Tv out connector' Link to comment Share on other sites More sharing options...
JustGav Posted January 23, 2010 Share Posted January 23, 2010 Have you tried the function keys to extend your desktop, Fn-7 sticks out for some reason. Also check control panel to see that the desktop is enabled. S-Video is definitely just 4pin, that I do know. Link to comment Share on other sites More sharing options...
Meko Posted January 23, 2010 Share Posted January 23, 2010 S-video connector on laptops is 7 pin female, but you'll need to do the FN + F(key) to switch to an external monitor. Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 S-video connector on laptops is 7 pin female, but you'll need to do the FN + F(key) to switch to an external monitor. Yeah Fn+ F8 on my laptop but it just goes on the tv for a second and its black & white Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 Have you tried the function keys to extend your desktop, Fn-7 sticks out for some reason. Also check control panel to see that the desktop is enabled. S-Video is definitely just 4pin, that I do know. What do you mean desk top enabled Link to comment Share on other sites More sharing options...
Pot Posted January 23, 2010 Share Posted January 23, 2010 2 things spring to mind... Does your 'S-Video' output port on your laptop have any colour around it? (Green/Purple) How many holes does the S-Video input on your TV have? Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 2 things spring to mind... Does your 'S-Video' output port on your laptop have any colour around it? (Green/Purple) How many holes does the S-Video input on your TV have? No colour around it and the s-video wire only has a single pin on the other end. I have to plug a jack to jack lead from headphones to the audio on the tv. Link to comment Share on other sites More sharing options...
Pot Posted January 23, 2010 Share Posted January 23, 2010 the s-video wire only has a single pin on the other end That surely isn't an S-Video connection? Can you take a pic of it? EDIT : Best to take pics of 'everything' Link to comment Share on other sites More sharing options...
Meko Posted January 23, 2010 Share Posted January 23, 2010 doesn't sound like one but it's sticking a picture on the screen and then going off so it's passing a signal down it. Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 Heres a few pics, hopefully they're ok Link to comment Share on other sites More sharing options...
Meko Posted January 23, 2010 Share Posted January 23, 2010 S-Video to RCA cable by the look of it. Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 S-Video to RCA cable by the look of it. So should this work? Link to comment Share on other sites More sharing options...
Pot Posted January 23, 2010 Share Posted January 23, 2010 Ah, so it's S-Vid to composite (The single pin end) - According to this http://www.notebookreview.com/default.asp?newsID=3089 it is an S-Vid connection, so no worries about it being a PS-2 one... Does your TV have more connections round the back? Ones that look like phono connections, red white, and yellow, if so, plug it into the yellow one and see what happens... Link to comment Share on other sites More sharing options...
Meko Posted January 23, 2010 Share Posted January 23, 2010 it should yeah but an S-Video to RCA should have 3 cables, picture and 2 for audio so unless you're not bothered about sound it'd work. It could be the TV, video card could be set to too high a res / refresh rate. Link to comment Share on other sites More sharing options...
nevins Posted January 23, 2010 Share Posted January 23, 2010 Has your tv got a vga connector. Its the same as a pc monitor lead. This is what I use to connect to my plasma. Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 Ah, so it's S-Vid to composite (The single pin end) - According to this http://www.notebookreview.com/default.asp?newsID=3089 it is an S-Vid connection, so no worries about it being a PS-2 one... Does your TV have more connections round the back? Ones that look like phono connections, red white, and yellow, if so, plug it into the yellow one and see what happens... No none on the back. The one its in is yellow with V above it and works perfect when i plug my video cam in it. Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 it should yeah but an S-Video to RCA should have 3 cables, picture and 2 for audio so unless you're not bothered about sound it'd work. It could be the TV, video card could be set to too high a res / refresh rate. I've a jack to jack for sound so thats ok. How do i change the res on the video card? Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 Has your tv got a vga connector. Its the same as a pc monitor lead. This is what I use to connect to my plasma. Ha Ha thats a good one if you seen the tv its lucky to have a remote lol Link to comment Share on other sites More sharing options...
nevins Posted January 23, 2010 Share Posted January 23, 2010 lol, how about using a usb to rca like you get with a digital camera. Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 lol, how about using a usb to rca like you get with a digital camera. What way does this work? Will the usb pick up the tv and play threw the usb then? Link to comment Share on other sites More sharing options...
Pot Posted January 23, 2010 Share Posted January 23, 2010 lol, how about using a usb to rca like you get with a digital camera. I can smell what you're cooking there, but the graphics won't be configured to work like that... Link to comment Share on other sites More sharing options...
Pot Posted January 23, 2010 Share Posted January 23, 2010 What way does this work? Will the usb pick up the tv and play threw the usb then? No... Link to comment Share on other sites More sharing options...
Suprab1 Posted January 23, 2010 Author Share Posted January 23, 2010 Ok i have her on tv but she's still black & white. Any one know how to get colour? Link to comment Share on other sites More sharing options...
