S- video lead
Suprab1
Hi all just wondering about connecting my laptop (Dell inspiron 6400) to a tv. I got a s-video lead, plugged it all up but it just flashes on the tv for a second.
The lad in the shop said my computer must not be able to connect to the tv. I was just looking at the lead and it has 4 pins my computer has 7. Can this be whats wrong as i'm sure it doesn't have an s-video socket in it for a laugh cheers.
7 pin? sure that isn't the ps2 ouput from external mouse and keyboard. Check the manual :)
2 things spring to mind...
Does your 'S-Video' output port on your laptop have any colour around it? (Green/Purple)
How many holes does the S-Video input on your TV have?
No colour around it and the s-video wire only has a single pin on the other end. I have to plug a jack to jack lead from headphones to the audio on the tv.
Ah, so it's S-Vid to composite (The single pin end) - According to this http://www.notebookreview.com/default.asp?newsID=3089 it is an S-Vid connection, so no worries about it being a PS-2 one...
Does your TV have more connections round the back? Ones that look like phono connections, red white, and yellow, if so, plug it into the yellow one and see what happens...
No none on the back. The one its in is yellow with V above it and works perfect when i plug my video cam in it.
it should yeah but an S-Video to RCA should have 3 cables, picture and 2 for audio so unless you're not bothered about sound it'd work.
It could be the TV, video card could be set to too high a res / refresh rate.
I've a jack to jack for sound so thats ok. How do i change the res on the video card?
