kazama76 Posted January 23, 2010 Share Posted January 23, 2010 Hey guys sorry to bomb bard ya all wi questions on my 1st day Just bought a manual NA and its seems to have a slight vibrating coming from erm erm i dunno. Last owner says its the lower pully wheel, but i checked it and looks straight. Is this common? Any help appreciated Quote Link to comment Share on other sites More sharing options...
Ian W Posted January 23, 2010 Share Posted January 23, 2010 How can you feel the vibration? Can you feel it? If so where from? Is it felt through the whole car or just the steering wheel? More info required I think mate Quote Link to comment Share on other sites More sharing options...
Lbm Posted January 23, 2010 Share Posted January 23, 2010 Hi Kazama and welcome to the club. Just so you know, if you would title your threads accurately, (essential in the technical section a matter of fact) you'll probably get a few more replies - Also vaguely titled threads tend to get deleted. Anyway, I've re-titled it for you and hope you get your answer Quote Link to comment Share on other sites More sharing options...
kazama76 Posted January 23, 2010 Author Share Posted January 23, 2010 Cheers 4 the retitle :-) Erm through both the steering wheel and the gear stick mainly. But the whole car in general. My only other thought would be maybe a buckled alloy.. Quote Link to comment Share on other sites More sharing options...
Scott Posted January 23, 2010 Share Posted January 23, 2010 Is this on the move or while idling/revving? Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 23, 2010 Share Posted January 23, 2010 Ahem. Quote Link to comment Share on other sites More sharing options...
kazama76 Posted January 24, 2010 Author Share Posted January 24, 2010 only while moving the faster i go the worse it gets. Quote Link to comment Share on other sites More sharing options...
Scott Posted January 24, 2010 Share Posted January 24, 2010 Could be a few things. First thing to check is that it isn't the gearbox/flywheel etc. This is very easy. When driving and the vibrating is bad put your foot on the clutch to disengage it. If the vibrating goes away it is something to do with that IMO. If the vibrating stays the first thing to check is that your wheelnuts are all on properly. If everything is OK there then my guess would be wheel balancing or badly warped discs. In fact, just read that. The first thing to check is that your wheel isn't going to fall off lol. Check your wheel nuts, it is very unlikely but stranger things have happened. Quote Link to comment Share on other sites More sharing options...
kazama76 Posted January 24, 2010 Author Share Posted January 24, 2010 be right back, go do this now :-) Quote Link to comment Share on other sites More sharing options...
AlexM Posted January 24, 2010 Share Posted January 24, 2010 It could be a sticky brake caliper, I had horrible vibrations through my first Supra due to semi-working brakes! Quote Link to comment Share on other sites More sharing options...
kazama76 Posted January 24, 2010 Author Share Posted January 24, 2010 right just been 4 a quick spin, in fact ins NOT motion causing it. The vibration is rev related. Feeling a bit embarrased here but could this just be the rumble of the exhaust :-s Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 24, 2010 Share Posted January 24, 2010 Revving your car makes the steering vibrate ? Quote Link to comment Share on other sites More sharing options...
kazama76 Posted January 24, 2010 Author Share Posted January 24, 2010 Dont know, never had a supra before. i could feel similar vibration though my steering wheel in my impreza. just in this its a little more noticable Quote Link to comment Share on other sites More sharing options...
Ian W Posted January 24, 2010 Share Posted January 24, 2010 Best bet, take it to someone who knows what they're doing mate. Will save you a lot of hassle and you'll know without the *potential* problem dragging on. Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 24, 2010 Share Posted January 24, 2010 Does your car have a manual or auto gearbox ? Quote Link to comment Share on other sites More sharing options...
Scott Posted January 24, 2010 Share Posted January 24, 2010 Dont know, never had a supra before. i could feel similar vibration though my steering wheel in my impreza. just in this its a little more noticable That could be a few things to be honest. Some are engine critical so I would get it to someone who knows what they are doing bud. As above though, is it an Auto? I was just assuming manual. Quote Link to comment Share on other sites More sharing options...
nevins Posted January 24, 2010 Share Posted January 24, 2010 What type of vibration is it. Is it fast or slow vibration. Fast being as if something is vibrating against something like the exhaust pushed against the rear subframe or slow as in like a slight engine miss. Quote Link to comment Share on other sites More sharing options...
kazama76 Posted January 24, 2010 Author Share Posted January 24, 2010 It is indeed a manual. I convinced its exhaust related, the burble and vibration is almost in tune.. I will get it checked out, anyone know of a decent garage around the lincoln area? Quote Link to comment Share on other sites More sharing options...
Scott Posted January 24, 2010 Share Posted January 24, 2010 Has it been de-catted? If not it could be the CAT heatshield. They are known for making a bit of a racket. Quote Link to comment Share on other sites More sharing options...
ellis Posted January 25, 2010 Share Posted January 25, 2010 If you want to bring it round mate, happy to have a look and listen too. Have a few good contacts for garages in and around Lincoln if you want too. Quote Link to comment Share on other sites More sharing options...
kazama76 Posted January 27, 2010 Author Share Posted January 27, 2010 yes mate, it would be appreciated. will pm ya Quote Link to comment Share on other sites More sharing options...
