Kirk Posted January 22, 2010 Share Posted January 22, 2010 Over the last few weeks ive started noticing the frame rate on my TV keeps dropping. At 1st i thought it was just crap reception for a particular channel until it happened approaching the end of a dvd i was watching so it appears to be a problem with the TV itself. If i switch the TV on and off again it fixes the problem. Dont suppose anyone else has had this issue before? Quote Link to comment Share on other sites More sharing options...
hemmjonny Posted January 22, 2010 Share Posted January 22, 2010 is it a samsung if so needs a software update Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 23, 2010 Author Share Posted January 23, 2010 Good call my man! Its a samsung but how do I go about updating it? Plug it into a modem and let it do its thing? Quote Link to comment Share on other sites More sharing options...
Abz Posted January 23, 2010 Share Posted January 23, 2010 Martin, just had a quick look on the net. I presume the TV has a USB port? In which case you would need a USB cable to plug from the TV into a computer. Before you plug it into the computer you need to download the firmware update from Samsung down onto your computer, use the link below to find it. http://www.samsung.com/us/support/newsalert/supportNewsAlertMain.do Here are some instructions I found: 1. Download the firmware 2. Unzip it. 3. Launch the program on the desktop - it will prompt you, asking where you want to install the program. Choose the drive that the thumbdrive is in. 4. Install it 5. You should be able to plug it in your TV at this point. Hope this helps mate. Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 23, 2010 Author Share Posted January 23, 2010 Nice on mate! Ill give it a try Quote Link to comment Share on other sites More sharing options...
