nitro cars out for service
barneybrendan
  • Replies 90
if you cant be botherd your local model shop should set it up for you.great fun ,be interesting to see how many members have them.
My list: Built up so many over the years, I have to store them all in a secure work lock up.
cars:
Shengqi 1/5th 23cc hummer
XRC X1 23cc 1/5th touring car
Hpi Baja 5b 1/5th with 29cc conversion
Fg Monster beetle 1/5th 26cc
Fg marder race 1/5th 23cc
Fg Evo4 Race car 1/5th 29cc
Schumacher fusion 28 4.6
schumacher menace 4.6
Hpi savage 5.9 xl (sold)
Bycmo 1/7th scale dodge viper 4.6
Hot bodies lightning
Team associated rc10 T4
tamyia tt-01 drift spec car
tamiya mad bull
tamiya super saber x2
Thunder tiger ts 4n x2
bycmo electric subaru's x2
15 x vintage taiyo rc cars
Helicopters:
Thunder tiger raptor 30
thunder tiger raptor 50
thunder tiger raptor 60 (sold)
t rex 600 esp
t rex 500 esp
various indoor electric helis
Planes:
Seagull arising star 66" high wing trainer
st models cessna 182
multiplex sonic liner
sig rascal
Icarus nemesis shock flyer
Icarus Yak shock flyer
Kyosho minium cessna
Oh and 2 twin motor speed boats.
I'm going to start selling some of them now though, so if anyones interested in any I can send pics and more details.
i bought the mta4`s with broken gearboxes turned out the 2 speed shafts were broken.just put the blue one back together still no drive.with engine off i can select forward and reverse ,when i turn the fly wheel the truck moves in selected direction..Had the gearbox apart about 5 times now,replaced friction pins on the slipper clutch.I am really scratching my head now.
When i first put it together i was able to drive it down the road got into second gear,but as i drove it back up sounded like a slipping clutch.Am i missing something stupid:search:
Have you checked the slipper is totally tight, they only need to be the tiniest bit loose to slip, also check that you definitely have the two speed clutch hub the right way around.
slipper tight as i can get it spring fully compressed.as for the hub mmmm gearbox out again then.
The correct way to have it is if you roll the truck forward holding the spur gear while you do, you should have (looking through the rubber plugged hole in the side of the case the two speed half moon come up first, then the set screw, then the gear adjustment screw. This is assuming you have the truck in forward gear.
:), Nitro is worth it when they are running well though.
I tend to stick to my petrol models now, they are so easy to use and maintain, and hardly have any problems. They don't quite have the same buzz as a well tuned nitro though.
the hub is on the correct way.if i hold the truck still so it cant move and turn the spur gear the rear tries to squat down.
I’ve got 3 nitro cars. One is a race car (from the nitro racer mag) but it’s in bits because both diffs broke! I’ve also got 2 monster trucks but there in bits because I did a jump with one of them and broke both drive shafts and both need their engines setting up because I can’t get them running right!!
Most the Tamiya stuff is still self build, i enjoyed building my Supra.
Check out this, looks a handfull:cool:
http://www.youtube.com/watch?v=J03GmPRH2O8&NR
I love r/c drfiting, I have been doing it a while now.
A few people I know are starting rock crawling, not using the cheap 1/10th scale plastic crawlers but the 1/5 scale billet made machines, They all need to be assembled and look quite hard to build. I'm considering selling one of my better 1/5th models to buy one of these Killer Krawlers:
http://cgi.ebay.co.uk/RC4WD-Rock-Crawler-Killer-Krawler-LONG-Wheel-base_W0QQitemZ160387280358QQcmdZViewItemQQptZUK_ToysGames_RadioControlled_JN?hash=item2557d3ade6
Little video at the end to show what they can do.
Im thinking about buying one of these Brushless revos, watch the video, looks fast.
http://www.modelsport.co.uk/?CallFunction=ShowSpecification&ItemID=32872
Looks good but the charging of battery packs kills it for me, has to be nitro or petrol powered, just top the tank up and away you go :D
I have three Kyosho 1:10 electric cars, two belt driven 4WD escort cossies and a buggy, not been used for over 10 years :innocent:
One of our guys runs a brushless e-revo on 3s lipos. It eats all the petrols and nitros for breakfast lunch and dinner!
He gets about 15-20mins run time out of them so has a few sets, but I think he needed to pay about £100 a set.
Still, people spend as much on their nitro truggys at the races and aren't as fast.
Only problem now is finding tires that don't burst under full power!
hopefully found out my problem on both trucks,knackerd one way bearings.Fingers crossed the model shop has them in stock tomorrow if not they take about a week to order things in.
Did the model shop suggest the one way bearings? That normally gives you starting problems as well when they are knackered.
