nitro cars out for service
barneybrendan
Whats a good car to start off with? Used to have a petrol one years ago until it flipped upside down and reved the nuts out of itself and died. Just a petrol or nitro one to use on flat surfaces? I'd love one with a supra shell?
  • Replies 90
:thumbs:
:thumbs: Thank you, What sort of controller do I need? How do i make the controller work with the car? is it something to do with a crystal/chip? does that come with the car and you just plug into the controller?
(As I said its been a few years since i've touched one. lol)
I could be wrong but I think the RTR (ready-to-run) packs come with everything needed and the car is built.
Ohh yes, It says on there that it comes with a controller.
If I wanted to change the controller how would I do it? is it just a chip to change over?
Depends, It will probably come with a 27mhz system. They are ok but I would really change it for a 40mhz or 2.4ghz controller, Much safer if you are using it in a public place
If you had a control already you would just need to check it's the same frequency as the receiver in the car and put a matching crystal in it.
There are plenty of good cars out there depending what you are after. I consider myself to be very knowledgable on anything rc as I have been doing it so long.
One of my cars will do 100+mph, But that doesn't mean It will ever do it, The surface would have to be incredibly smooth, wide, long. Yet I have a 1/7th scale nitro which is good for 60 ish mph and because it is that much bigger than 1/10th it's more stable and will reach it's top speed, therfore being quicker than the 100mph one.
Petrol is so much easier than nitro, just fill up and run for 35-45 minutes with out the constant tuning issues and rebuilds etc.
I'm looking to sell some of my modelsm, so if you let me know what your after I may well have something of interest to you.
Pm on its way :search:
HA HA. Found my old beast, minus the engine.
Anyone know what it is or whether its worth buying an engine for?
(Needs a clean lol)
Clickable pics
http://i99.photobucket.com/albums/l304/s14a_200sx/th_S1051161.jpg
http://i99.photobucket.com/albums/l304/s14a_200sx/th_S1051160.jpg
It looks rather neglected :). I don't know what it is, And it probably won't be worth you mending it, looks like it will need more than just the engine.
one of my mta4`s hasnt got any crystals .what ones do i need to get,just tried 2 crystals from a different car and controler but they didnt work
You need to check if it's 27mhz or 40mhz, 27 is genrally done on colours so a green tx crystal will go with a green rx crystal, If they are 40 it is the last three numbers that have to match. Also some are specific to each manufacturer.
