UK Euro spec turbos with ceramic turbine wheels?
Chris Wilson
There are 4 Uk / Euro spec turbos of a customers at Turbo Dynamics to build a good pair, and TD rang me to say one pair had ceramic impellers, one pair had steel. Now I have seen a LOT of 2JZ-GTE turbos in my time, and had a good few rebuilt, but this is only the second time for UK / Euro spec turbos with ceramic wheels. They are definitely UK / Euro as they are 4 stud onto the manifold unless VVTi ones are 4 stud, but from memory I don't think they are. Anyone? Pete Sharp's factory original UK car had these as well, I thought it a one off at the time.... See this old thread:
http://www.mkivsupra.net/vbb/showthread.php?t=124188
Guest SupraGTE
Toyota have something called "running changes"...it is PITA :) as there is hardly no record for a normal living to find out what exacty is done .
just an examples on running changes :
navigation for Auris:
first year and a half we installed navis and routed cables for speed and reverse behind dashbord, just like a suprise we started seeing that some vehicles started coming prewired:) just plug and play , even today we have hard to track which ones are prewired and not :)
"running changes" can be material change, change of supplier, cost saving etc so in teori a part can be aluminium but be changed to some else material and a substitute Part number is made for it so f you order the old you recive the new.
I think there was a discussion about 3 years ago about US turbos possibly having ceramic internals but being 4 stud pattern.
Never got proved either way but it has been discussed before and finding the answer would be good.
Are the internals actually the same size as j-spec or the UK spec?
UK spec diameter wheels, but ceramic. Thanks John.
