Wez Posted January 19, 2010 Share Posted January 19, 2010 (edited) Hey All, Instead of keeping this link I thought it would be better to do an online table. Any corrections or additions let me know, we could also use this thread to discuss future engine builds/combos and the possible RPM limits etc Stock 2JZGTE: 86mm Bore x 86mm Stroke - 8.620" Block Height PISTONS [table=head;sort=1,2,3]Description|Weight|Notes Stock 86.00mm|407 Grams|na JUN C Series (Cosworth) 87.00mm|343g|Pin 104 Grams - Cosworth part# PA1737 JUN W Series (Wossner) 86.50mm|362g|OE Comp 8.5:1 - Wossner Comp 8.0:1 - Wossner Part# K9057D050 JUN W Series (Wossner) 87.00mm|362g|OE Comp 8.5:1 - Wossner Comp 8.0:1 - Wossner Part# K9057D100 HKS 87.00mm Forged|384g|Pin 112 Grams CP 86.00mm|na|na CP 86.50mm|322g|na CP 87.00mm|na|na CP 87.00mm 3.4 Stroker|328g|9.1cr JE 87.00mm Forged|306g|8.5cr JE 86.50mm Forged|304g|8.5cr JE 86.50mm Forged|330g|8.0cr JE 87.00mm Forged|333g|8.0cr Wiseco|na|na Arias 86.50mm|355g|na Arias 87.00mm|362g|na Tomei|na|na Toda 86.00mm Forged|na|na Toda 87.00mm Forged|na|na Crower|338g|Bore: 3.405, +.020 - Comp: 8.5:1 Mahle 87.00mm|332.5g|Pro Series Pistons [/table] RODS [table=head;sort=1,2,3]Description|Weight|Notes Stock Rod stripped|761g|na Stock Rod with bearing|800g|na Stock Wrist Pin|132g|na Carillo H beams|580g|na Carillo incl bolts|602g|na Brian Crower I Beam|495g|Bolt 57g Brian Crower H Beam Pro Series|na|na BC Pro with bolts|605g|na Pauters|680g|na Eagle with bolts|586g|na Crower Titanium|392g|na [/table] CRANK [table=head;sort=1,2,3]Description|Weight|Notes Stock|59.6lbs|na HKS 3.4 Stroker|52lbs|na BC 3.4 Stroker|na|na BC 3.4 Stroker|48lbs|Lightweight 94mm JUN 3.4 Stroker|na|na Winberg|45lbs|na Spool 3.4 Stroker|52lbs|na [/table] Edited July 10, 2013 by Wez (see edit history) Link to comment Share on other sites More sharing options...
JamieP Posted January 19, 2010 Share Posted January 19, 2010 (edited) Interesting stuff mate, i would be interested to know what the normal BC rods weigh if anyone has the info:) Edited January 19, 2010 by JamieP (see edit history) Link to comment Share on other sites More sharing options...
dandan Posted January 19, 2010 Share Posted January 19, 2010 Nice one Wes Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 (edited) Talking to Cosworth we could potentially use the new Mitsubishi EVO X 4B11 pistons. I have found another contact for Cosworth which has now answered most of the questions raised earlier 1) Could they be made with oil galleys like the stock piston as the 2JZ-GTE has oil squirter's to aid cooling? Do you mean cut outs in the skirt to accomodate the oil sprays? Yes no problem, but we would need an OE sample to measure from. 2) Will the gudgeon pin diameter be the same as stock? 22mm pin as stock and yes they will. 3) Can they be low friction/anti det coated? There is a low friction bedding in coating included in the price quoted on the piston skirts. The Crowns are mirrior polished to help anti-detonation, again included in the price (both of these are normally cost extras). 4) Would the valve relief be large enough for +1mm valves? Max valve size allowed is 33mm Inlet, 28mm Exhaust 5) What is the Crown volume? Do you mean the Bowl CC? 6) Is 86.00mm, 86.50mm and 87.00mm available, if so in the same batch? Yes, all available in the same batch. 7) How much do they weigh? Depends on bore size. As Cosworth have not made these in a while (using the new forging at least) they are unlikely to be able to give an accurate figure today. If there is sufficent interest (ie orders) then they can do a more up to date model which will give them a predicted weight accurate to about 98%. They will only take the time to do this however if it looks like they will sell some. Im sure you can appreciate that considering the time involved in redrawing pistons and the number of enquiries, it has to be on a priority basis. 8) Are low compression versions available, if so can they be done in the same batch? After the initial batch of 48pcs is done, further pistons can be low comp. >48pcs as oe. 49pcs> can be low comp so in short, you will need 8 OE comp ratio customers before the low comp orders can be processed. OE comp ratio by the way is 8.5:1. As long as you dont go lower then about 8.0:1, this shoud be possible but I would need you to come back to me with firm numbers before I can say for sure. 9) Is the compression height same as stock? Compression height is same as stock. Edited January 22, 2010 by Wez (see edit history) Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 19, 2010 Share Posted January 19, 2010 Interesting stuff mate, i would be interested to know what the normal BC rods weigh if anyone has the info:) During my build with Mark we swopped at the last minute from Eagle to BC rods and ARP bolts, the weight difference was significantly less, we did weigh them so I will search to see if I can find it Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 During my build with Mark we swopped at the last minute from Eagle to BC rods and ARP bolts, the weight difference was significantly less, we did weigh them so I will search to see if I can find it That would be great thanks Link to comment Share on other sites More sharing options...
Nic Posted January 19, 2010 Share Posted January 19, 2010 Toda Racing also do piston sets for the 2JZGTE and 2JZGE, although they don't list weights. Toda ø86mm Forged Toda ø87mm Forged Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 Toda Racing also do piston sets for the 2JZGTE and 2JZGE, although they don't list weights. Toda ø86mm Forged Toda ø87mm Forged Updated thanks Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 19, 2010 Share Posted January 19, 2010 What's the pin height on the Evo pistons? Pin diameter? Crown volume? Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 19, 2010 Share Posted January 19, 2010 That would be great thanks This was from Dusty from this thread on the BC rods I purchased http://www.mkivsupra.net/vbb/showthread.php?t=135209&highlight=brian+crower+rods This is what I got from Brian Crower, dont know if it makes sence The rods we have in stock right now are "I" beam and the weight are 495 (g) The bolts weigh 57 grams. Thank you, Dustin Link to comment Share on other sites More sharing options...
Nic Posted January 19, 2010 Share Posted January 19, 2010 (edited) JUN do 3 piston options http://www.junauto.co.jp/products/piston/detail.html?en JUN C Series (Cosworth) 87mm JUN W Series (Wossner) 86.5mm JUN W Series (Wossner) 87mm http://www.woessner-kolben.de/english/katalog/toyota.pdf Edited January 19, 2010 by Nic (see edit history) Link to comment Share on other sites More sharing options...
JamieP Posted January 19, 2010 Share Posted January 19, 2010 This was from Dusty from this thread on the BC rods I purchased http://www.mkivsupra.net/vbb/showthread.php?t=135209&highlight=brian+crower+rods This is what I got from Brian Crower, dont know if it makes sence The rods we have in stock right now are "I" beam and the weight are 495 (g) The bolts weigh 57 grams. Thank you, Dustin Light rods, I hope the H beam are a similar weight to the I beam, i went with the Brian Crower Pro Series H beam Rods, they will be here very soon and i will weigh them. Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 This was from Dusty from this thread on the BC rods I purchased http://www.mkivsupra.net/vbb/showthread.php?t=135209&highlight=brian+crower+rods This is what I got from Brian Crower, dont know if it makes sence The rods we have in stock right now are "I" beam and the weight are 495 (g) The bolts weigh 57 grams. Thank you, Dustin JUN do 3 piston options http://www.junauto.co.jp/products/piston/detail.html?en JUN C Series (Cosworth) 87mm JUN W Series (Wossner) 86.5mm JUN W Series (Wossner) 87mm http://www.woessner-kolben.de/english/katalog/toyota.pdf Updated Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 What's the pin height on the Evo pistons? Pin diameter? Crown volume? I will try and find out, it seems my previous contact is no longer there Link to comment Share on other sites More sharing options...
TLicense Posted January 19, 2010 Share Posted January 19, 2010 Light rods, I hope the H beam are a similar weight to the I beam, i went with the Brian Crower Pro Series H beam Rods, they will be here very soon and i will weigh them. The weight of the rods, whilst you would want them to be as light as possible, has a far smaller effect on the bolt loading than the weight of the piston. I would tend to sacrifice a little weight for a stronger component. Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 The weight of the rods, whilst you would want them to be as light as possible, has a far smaller effect on the bolt loading than the weight of the piston. I would tend to sacrifice a little weight for a stronger component. What do you think of the titanium jobbies then Link to comment Share on other sites More sharing options...
TLicense Posted January 19, 2010 Share Posted January 19, 2010 What's the pin height on the Evo pistons? Pin diameter? Crown volume? I will try and find out, it seems my previous contact is no longer there I may be able to find out as I think there's a guy here who has just rebuilt a 4B11. He may well have the old pistons hanging around. Obviously if Cosworths pistons are different to stock then it won't really tell us much... Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 I may be able to find out as I think there's a guy here who has just rebuilt a 4B11. He may well have the old pistons hanging around. Obviously if Cosworths pistons are different to stock then it won't really tell us much... All the other pistons in the catalogue have a 22mm pin hole, it doesnt list the 4B11 though Link to comment Share on other sites More sharing options...
Homer Posted January 19, 2010 Share Posted January 19, 2010 Great work Wes. Moved to Technical reference section and stickied Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 Great work Wes. Moved to Technical reference section and stickied Link to comment Share on other sites More sharing options...
Wez Posted January 20, 2010 Author Share Posted January 20, 2010 (edited) Updated the Cosworth post http://www.mkivsupra.net/vbb/showpost.php?p=2636325&postcount=4 Edited January 22, 2010 by Wez (see edit history) Link to comment Share on other sites More sharing options...
Wez Posted January 20, 2010 Author Share Posted January 20, 2010 JUN do 3 piston options http://www.junauto.co.jp/products/piston/detail.html?en JUN C Series (Cosworth) 87mm JUN W Series (Wossner) 86.5mm JUN W Series (Wossner) 87mm http://www.woessner-kolben.de/english/katalog/toyota.pdf You can buy the Wossner pistons direct in the UK from PEC [table=head]Description|ex VAT|inc VAT PEC Supra 2JZGTE 3.0 Turbo Pistons|£637.45 ex VAT|£749.00 inc. VAT PEC Supra 2JZGTE 3.0 Turbo Forged Con Rods|£606.38 ex VAT|£712.50 inc. VAT Supra 3.0 2JZGTE Turbo Wossner piston & PEC rod package|£1,153.18 ex VAT|£1,354.99 inc. VAT [/table] http://www.performanceenginecomponents.com/products/product.asp?id=208 Link to comment Share on other sites More sharing options...
Ryan.G Posted January 22, 2010 Share Posted January 22, 2010 Nice work Wes!! Link to comment Share on other sites More sharing options...
Wez Posted January 22, 2010 Author Share Posted January 22, 2010 I have found another contact for Cosworth which has now answered most of the questions raised in the previous group buy thread 1) Could they be made with oil galleys like the stock piston as the 2JZ-GTE has oil squirter's to aid cooling? Do you mean cut outs in the skirt to accomodate the oil sprays? Yes no problem, but we would need an OE sample to measure from. 2) Will the gudgeon pin diameter be the same as stock? 22mm pin as stock and yes they will. 3) Can they be low friction/anti det coated? There is a low friction bedding in coating included in the price quoted on the piston skirts. The Crowns are mirrior polished to help anti-detonation, again included in the price (both of these are normally cost extras). 4) Would the valve relief be large enough for +1mm valves? Max valve size allowed is 33mm Inlet, 28mm Exhaust 5) What is the Crown volume? Do you mean the Bowl CC? 6) Is 86.00mm, 86.50mm and 87.00mm available, if so in the same batch? Yes, all available in the same batch. 7) How much do they weigh? Depends on bore size. As Cosworth have not made these in a while (using the new forging at least) they are unlikely to be able to give an accurate figure today. If there is sufficent interest (ie orders) then they can do a more up to date model which will give them a predicted weight accurate to about 98%. They will only take the time to do this however if it looks like they will sell some. Im sure you can appreciate that considering the time involved in redrawing pistons and the number of enquiries, it has to be on a priority basis. 8) Are low compression versions available, if so can they be done in the same batch? After the initial batch of 48pcs is done, further pistons can be low comp. >48pcs as oe. 49pcs> can be low comp so in short, you will need 8 OE comp ratio customers before the low comp orders can be processed. OE comp ratio by the way is 8.5:1. As long as you dont go lower then about 8.0:1, this shoud be possible but I would need you to come back to me with firm numbers before I can say for sure. 9) Is the compression height same as stock? Compression height is same as stock. Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 22, 2010 Share Posted January 22, 2010 What do you think of the titanium jobbies then Having had to buy a new set of Ti rods for my Mugen V8 I don't think I'll be buying any more in the foreseeable future, I am on offal and water as it is Link to comment Share on other sites More sharing options...
