Reseal the 6Spd Gearbox
Pred
  • 2 weeks later...
Guest KSTUNING
I think amoniac free gasket mass will do the job... If it smells Amoniac dont use it! Amoniac/Acid is no good on metal...
Permatex has some good items for your needs... The grey tube gasket mass is Amoniac free...
http://www.autobarn.com.au/AB_images/products/images/prod_1197430754.jpg
Edited by KSTUNING (see edit history)
There are three external oil seals, the input shaft seal, the propshaft adaptor seal, and the gear selector shaft seal. I usually have all of these in stock cheaper than Toyota, but as you are in Germany it'll be easier to just get them from a local Toyota dealer. You need a puller for the prop adaptor, and the old selector shaft seal is a real fiddle to get out. You should buy a proper set of manuals if you intend a lot of DIY on these things, they are worth their weight in gold.
