Pred Posted January 19, 2010 Share Posted January 19, 2010 Hey, this is my gearbox: I want to reaseal it. Which seal would i need? Do I need special tools? Regards Andi Quote Link to comment Share on other sites More sharing options...
Pred Posted February 1, 2010 Author Share Posted February 1, 2010 can anyone help me :/ ? Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted February 1, 2010 Share Posted February 1, 2010 I would say nick or chris wilson will probably know wait until they come on line! Quote Link to comment Share on other sites More sharing options...
Guest KSTUNING Posted February 1, 2010 Share Posted February 1, 2010 (edited) I think amoniac free gasket mass will do the job... If it smells Amoniac dont use it! Amoniac/Acid is no good on metal... Permatex has some good items for your needs... The grey tube gasket mass is Amoniac free... http://www.autobarn.com.au/AB_images/products/images/prod_1197430754.jpg Edited February 1, 2010 by KSTUNING (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 1, 2010 Share Posted February 1, 2010 There are three external oil seals, the input shaft seal, the propshaft adaptor seal, and the gear selector shaft seal. I usually have all of these in stock cheaper than Toyota, but as you are in Germany it'll be easier to just get them from a local Toyota dealer. You need a puller for the prop adaptor, and the old selector shaft seal is a real fiddle to get out. You should buy a proper set of manuals if you intend a lot of DIY on these things, they are worth their weight in gold. Quote Link to comment Share on other sites More sharing options...
rockatanski Posted February 5, 2010 Share Posted February 5, 2010 Hi Pred, give me pm with you phonenumber, already did the job on mine ;-) Greets Rocka Quote Link to comment Share on other sites More sharing options...
