Wez Posted January 18, 2010 Share Posted January 18, 2010 Hey All, Does anyone have the EPC software installed that can show an exploded diagram of a NA auto and a TT auto diff? Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 18, 2010 Share Posted January 18, 2010 I can put it up in the morning if homer doesn't beat me to it? A bit woosey with the medication at the minute otherwise I would now Quote Link to comment Share on other sites More sharing options...
Wez Posted January 18, 2010 Author Share Posted January 18, 2010 Top stuff thanks Quote Link to comment Share on other sites More sharing options...
Homer Posted January 18, 2010 Share Posted January 18, 2010 Lots of EPC options here mate, do you need the LSD or non-LSD diagrams? Hate the last version of EPC which is the only one that works on Win7, it's not easy to post these things in any detail Quote Link to comment Share on other sites More sharing options...
Homer Posted January 19, 2010 Share Posted January 19, 2010 Here's what I could get, if you need more detail let me know. (Hover over the attachment to see the file description). Not convinced on these as the NA LSD and TT auto figures have the same number, though the part numbers are different Quote Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 Thanks matey, the bit I am interested in is the propshaft mount, 41204, they come in different sizes for NA and TT, can we show this using part numbers and I wonder if just that part can be changed/swapped. Quote Link to comment Share on other sites More sharing options...
Homer Posted January 19, 2010 Share Posted January 19, 2010 Thanks matey, the bit I am interested in is the propshaft mount, 41204, they come in different sizes for NA and TT, can we show this using part numbers and I wonder if just that can be changed. If you can PM me with a chassis and model number for the NA I'll check it out. However the NA 5spd/ NA auto prop difference comes into question. What exactly and you fitting to what? I've completely lost track now Quote Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 If you can PM me with a chassis and model number for the NA I'll check it out. However it the NA 5spd/ NA auto prop difference comes into question. What exactly and you fitting to what? I've completely lost track now Sat on my garage floor is a diff from an NA auto, I am looking to fit this to my TT which currently has the larger diff fitted, code B03B Quote Link to comment Share on other sites More sharing options...
Homer Posted January 19, 2010 Share Posted January 19, 2010 Sat on my garage floor is a diff from an NA auto, I am looking to fit this to my TT which currently has the larger diff fitted, code B03B Surely that's not possible? The larger diff casing can't suport the smaller diff. Crown wheel and ring gear are not compatible according to TMC specs... for a start Quote Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 This is the diff I purchased http://www.mkivsupra.net/vbb/showthread.php?t=206979 Here is a thread about swapping them over http://www.mkivsupra.net/vbb/showthread.php?t=206416 Quote Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 Surely that's not possible? The larger diff casing can't suport the smaller diff. Crown wheel and ring gear are not compatible according to TMC specs... for a start I have a complete diff, casing and everything, not looking to swap the internals, the whole lot needs swapping over and I will get another LSD possibly OS Giken or TRD for the smaller casing Quote Link to comment Share on other sites More sharing options...
David P Posted January 19, 2010 Share Posted January 19, 2010 (edited) Edit: You will need to change the prop flange to suit the T.T. prop, and think you will need to fit the driveshafts that go with the small casing diff. Edited January 19, 2010 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 19, 2010 Share Posted January 19, 2010 I am right in saying then wez your NA has the large TT diff currently fitted it and your just swapping to the smaller diff? Quote Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 I am right in saying then wez your NA has the large TT diff currently fitted it and your just swapping to the smaller diff? No My single has the large diff and i want to swap to smaller diff with different ratio ring/pinion which is only available on smaller diff I have a spare NA auto diff sitting here that I want to use. Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 19, 2010 Share Posted January 19, 2010 (edited) Right I get you now I didn't know they actualy did diffs for the smaller casing... Interesting, giving me ideas now :eyebrows Be interesting to find out if the smaller diff casing can be adapted to suit the bigger prop. It sounds crazy BUT what about adapting the rear half of the smaller prop to the TT front? Either that or a nice 1 piece propshaft (expensive) with the correct flanges on each end maybe Saves messing with the diff case unless it can be modified easily Edited January 19, 2010 by Kirk (see edit history) Quote Link to comment Share on other sites More sharing options...
Wez Posted January 19, 2010 Author Share Posted January 19, 2010 I have been told that I will need a passenger/near side drive shaft with ABS ring, a UK auto spec one will do. The prop flange should be fine as it was only changed on late model 6 speed NAs, the PCB of the four bolts to the flange should be 114.7mm, the late model 6 speed NA are about 1 1/2mm different. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 20, 2010 Share Posted January 20, 2010 If you undo the prop flange nut you should really fit a new crush spacer and reset the bearing preload for the pinion bearing. There are workarounds, but not technically very "nice" ones.... Quote Link to comment Share on other sites More sharing options...
