Richard Posted January 18, 2010 Share Posted January 18, 2010 hi all,just been checking steel brake pipes on my 96 n/a and have found some light corrosion where the pipes curve around the body up into the rear wheel arch,think i have cought it in time as the pipes are not pitted so i think a clean up and a coat of paint should do the job.would just like to know if the plastic pipe cover that runs under the floor to protect the pipes also curves up into the arch as i'm not sure if i have a section missing.thanks Quote Link to comment Share on other sites More sharing options...
David P Posted January 19, 2010 Share Posted January 19, 2010 Take a look at the pics in the rotted brake lines sticky at the top of this page, that might help. Quote Link to comment Share on other sites More sharing options...
David P Posted January 19, 2010 Share Posted January 19, 2010 Is this want you want to see? Quote Link to comment Share on other sites More sharing options...
Richard Posted January 19, 2010 Author Share Posted January 19, 2010 Thanks for pics.this is what i have fitted,did not know if the plastic box in the corner of the shot should carry on around the corner as the rest of these pipe clips have the cover clipped to them. Thanks again. Quote Link to comment Share on other sites More sharing options...
David P Posted January 20, 2010 Share Posted January 20, 2010 You're welcome. Quote Link to comment Share on other sites More sharing options...
