Guest reiss Posted January 18, 2010 Share Posted January 18, 2010 Hey ! Ive just purchased a supra with a single turbo conversion and its blown the crankshaft seal when the turbo was running on high boost the turbo's a t4 t45 from x s power and its got an upgraded intercooler can anyone set me off in the right direction to setting the car up properly and also does anyone know of any places in lancashire that remap the ecu's for the supra? Link to comment Share on other sites More sharing options...
Wez Posted January 18, 2010 Share Posted January 18, 2010 First of all welcome Do you have the full spec of the car, maybe some details of where you purchased it as someone on here may know or thing or too about it. Link to comment Share on other sites More sharing options...
JamieP Posted January 18, 2010 Share Posted January 18, 2010 Welcome, Sounds like you have some big problems. Its going to be an oil pump change at a minimum id say, when people just try and replace the seal it blows very quickly again, sometimes it seems to be a sign of a very worn engine. What ecu do you have? Good luck with anything xs power, i feel you are going to need it. Jamie:) Link to comment Share on other sites More sharing options...
Guest reiss Posted January 18, 2010 Share Posted January 18, 2010 yeah i purchased the car from widnes off a mechanic all i know is that hes put a t4 t45 turbo on it and an aftermarket intercooler the rest is all standard its still running off the standard ecu Link to comment Share on other sites More sharing options...
Wez Posted January 18, 2010 Share Posted January 18, 2010 My advice would be take it to a recommended supra specialist for a once over. Link to comment Share on other sites More sharing options...
Kirk Posted January 18, 2010 Share Posted January 18, 2010 Ouch sounds expensive already! Oil pumps arnt that much new just a TWAT to fit, with engine in. I'd say get it checked over fully and makesure it is just that before you start throwing money at it Welcome fellow north westener! Link to comment Share on other sites More sharing options...
Guest reiss Posted January 18, 2010 Share Posted January 18, 2010 does anyone know anywhere decent in lancashire i can take it for a check over? Link to comment Share on other sites More sharing options...
Kirk Posted January 18, 2010 Share Posted January 18, 2010 Where abouts are you exactly? Link to comment Share on other sites More sharing options...
Guest reiss Posted January 19, 2010 Share Posted January 19, 2010 in blackburn Link to comment Share on other sites More sharing options...
JamieP Posted January 19, 2010 Share Posted January 19, 2010 yeah i purchased the car from widnes off a mechanic all i know is that hes put a t4 t45 turbo on it and an aftermarket intercooler the rest is all standard its still running off the standard ecu You are going to need to spend a fortune on that to get it running right and you will still be on a xspower kit, might be better to put it back to stock twins, or start over with the single conversion with a good quality kit, if i was you id never let that car come on boost till sorted. Link to comment Share on other sites More sharing options...
Jake Posted January 19, 2010 Share Posted January 19, 2010 put a t4 t45 turbo on it and an aftermarket intercooler the rest is all standard Ive just purchased a supra with a single turbo conversion and its blown the crankshaft seal when the turbo was running on high boost Ouch. I don't think you are going to enjoy Supra ownership much mate. When you say 'high boost' how high are we talking about? From what you've said above it sounds like your car still has the standard fuel injectors. Std injectors can barely enough for BPU let alone a single turbo at anythng even approaching high boost. Was the car originally a TT or a NA? You might well be better of junking most of the XS power stuff. Their turbos and manifolds are utter garbage. The intercoolers and exhausts are the only parts I would even consider using. Best of luck dude. Link to comment Share on other sites More sharing options...
The-Plethora Posted January 19, 2010 Share Posted January 19, 2010 I would get a full check over, maybe Whiffbits can help you out. I have only been here a short while but I have seen a bunch of threads about XS stuff not being great quality, hope you can get it fixed up. Link to comment Share on other sites More sharing options...
csa Posted January 19, 2010 Share Posted January 19, 2010 ...this could be a veeery long and educational thread Link to comment Share on other sites More sharing options...
Geo Posted January 19, 2010 Share Posted January 19, 2010 Take it from someone who ran there stuff for a while, all being i had no problems(which i was real lucky with) i decided i wanted to do a better install. When the old stuff was taking off Ian who did my single build was shocked to see the state of the parts. Id be saving my pennies up and changing all XS Power stuff for newer well made parts, money talks when doing a single build. Im glad i did change mine, as im sure the car would of went tits up when running the Xs power gear. Link to comment Share on other sites More sharing options...
Kirk Posted January 19, 2010 Share Posted January 19, 2010 All the above is good advice and ill 2nd it all. Going cheap on single turbo kits usualy ends badly and you end up with a large bill at the end. To be fair though some people have ran OK for a fair while on xs stuff with good results but eventualy the cheapness will bite you in the arse Link to comment Share on other sites More sharing options...
Alex Posted January 19, 2010 Share Posted January 19, 2010 Take it to Chris Wilson in Shropshire. He'll tell you the car is junk, but he's also the best at fixing it too Can't believe someone suggested carting it to London lol Link to comment Share on other sites More sharing options...
Guest reiss Posted January 19, 2010 Share Posted January 19, 2010 Ok well for starters the car was originally a tt so once the cars fixed can anyone advice me on a good quality single turbo set up e.g make and also what other bits ill need to change really appreciate all the help guys Link to comment Share on other sites More sharing options...
Alex Posted January 19, 2010 Share Posted January 19, 2010 BoostLogic, PHR, Whifbitz, HKS etc all make good kit. Thing to do, is set your goals and your budget. Then find the kit to suit them. Link to comment Share on other sites More sharing options...
magictorch Posted January 19, 2010 Share Posted January 19, 2010 BoostLogic, PHR, Whifbitz, HKS etc all make good kit. Thing to do, is set your goals and your budget. Then find the kit to suit them. Good advice....take a look in the projects section, plenty of single project cars for you to get a good idea;) Link to comment Share on other sites More sharing options...
T2 MSW Posted January 19, 2010 Share Posted January 19, 2010 Id vote for the Whifbitz one for two reasons, 1 Cost as its cheaper than some of the kits from the states and 2 the parts are better quality. The No1 selling factor for me besides my car being the guinea pig was the manifold has a 5 year garentee Link to comment Share on other sites More sharing options...
Geo Posted January 19, 2010 Share Posted January 19, 2010 Id vote for the Whifbitz one for two reasons, 1 Cost as its cheaper than some of the kits from the states and 2 the parts are better quality. The No1 selling factor for me besides my car being the guinea pig was the manifold has a 5 year garentee im running one on my single, and it does look the nuts. And works really well. Link to comment Share on other sites More sharing options...
Kirk Posted January 19, 2010 Share Posted January 19, 2010 That's until you decide having 2 wastegates is better than 1 Ill vouch for the whifbitz kit also, I've seen it in person MANY times now and the quality is supurb on all the pipework plus the fact its made over this side of the pond so no high cost import charges and huge waiting times Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 19, 2010 Share Posted January 19, 2010 High boost single on a stock ecu and injectors, blown crank seal, I just hope you dont need a new engine let alone a single kit I feel for you as this car will end up costing £1000,s to put right and I have not even seen it Might be worth considering cutting your losses and selling on and starting again Link to comment Share on other sites More sharing options...
Guest reiss Posted January 19, 2010 Share Posted January 19, 2010 Thanks guys for all info you guys have been great help !!! Link to comment Share on other sites More sharing options...
Geo Posted January 19, 2010 Share Posted January 19, 2010 Thanks guys for all info you guys have been great help !!! keep us posted on how you get on mate?? Link to comment Share on other sites More sharing options...
