What Kinda Battery Are You Guys Running??
Geo
My Battery is Fubard, it looks as if its been in since the car rolled off the production line. Since the Jspec battery uses the smaller terminals im just Wondering what you guys are running??, im looking into getting one of the Optima Batteries, as these look the nuts. :D
This may have been posted up many times, iv done the searches and not alot has come up, so tuff if its been covered before.
cheers
I will be changing to a sealed redtop optima when I put the battery in the boot, thought about a yellowtop but I dont think I need a deep cycle and I would prefer the huge cranking current of the redtops.
If you want a toyota replacement the toyota PN is number is 28800-yzzae. Thats what I have now and its worked flawlessly and because its a toyota replacement the posts are in the right position. Think they run about 50 note.
was going to go the Mr T route, but i'll be doing some more mods to the car and she did struggle to fire with this cold weather we had, hence looking at the Optima's. £140 on ebay, :D
I read somewhere that you can get them cheap from farming machinery suppliers as they get used on tractors and the like. £140 sounds good though, I seen some advertised at nearly £200 in places, just proves shopping around pays off:)
I have a little 38ah battery in my boot, car started first pull today after 3 weeks of doing nothing. At first, when I fitted it a year or so ago, I thought it was not up to the job, until I found the current draw when the alarm was set.
What's with all the foil Jamie, you been watching to many conspiracy films?;)
Edited by Terminator (see edit history)
For a jspec replacement with small terminals you should look at a Yuasa from somewhere like AllParts, dont go for 005 as thats a UK replacement with large terminals ;)
It's definitely small terminals on your car, Geo. I've jump started it three times in the last few hours so have had a good view of them :D
