hodge Posted January 18, 2010 Share Posted January 18, 2010 I'm going to relocate this and want it hidden. When it's fitted does it need to be higher than the pump or will I get away with putting it below the passanger headlight. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted January 18, 2010 Share Posted January 18, 2010 when i had to relocate the one on my na i had to have it higher than the pump ,was a bit of trial and error.if it was lower i couldnt seem to get rid of the air and would keep frothing up. Quote Link to comment Share on other sites More sharing options...
hodge Posted January 18, 2010 Author Share Posted January 18, 2010 thought as much. Cheers dude. Quote Link to comment Share on other sites More sharing options...
jevansio Posted January 18, 2010 Share Posted January 18, 2010 John are you using the stock one? The one I got from Whiffin looks the business if you want something a bit bling in the engine bay Quote Link to comment Share on other sites More sharing options...
Kopite Posted January 18, 2010 Share Posted January 18, 2010 John are you using the stock one? The one I got from Whiffin looks the business if you want something a bit bling in the engine bay Pics? Quote Link to comment Share on other sites More sharing options...
hodge Posted January 18, 2010 Author Share Posted January 18, 2010 John are you using the stock one? The one I got from Whiffin looks the business if you want something a bit bling in the engine bay Ideally I want to hide it Jay. I was gona put it under the passanger light but that seems a bad idea now. Im considering putting it behind the TRD vent in the front wing. The only issue will be the pipe is gona be pretty long to the pump. Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 18, 2010 Share Posted January 18, 2010 The lowest outlet in the tank must be higher than the entry to the pump. May be an electric pump system might help? Quote Link to comment Share on other sites More sharing options...
hodge Posted January 18, 2010 Author Share Posted January 18, 2010 Is there any consiquence to the pipe to the pump being long. Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 18, 2010 Share Posted January 18, 2010 Dare I ask why you're hiding a service item away? Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted January 18, 2010 Share Posted January 18, 2010 How about a Saxo electric pump, you can put that in the boot, well out the way. Quote Link to comment Share on other sites More sharing options...
hodge Posted January 18, 2010 Author Share Posted January 18, 2010 Dare I ask why you're hiding a service item away? I want the engine bay as clean and empty as pos. Quote Link to comment Share on other sites More sharing options...
jevansio Posted January 18, 2010 Share Posted January 18, 2010 Pics? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 18, 2010 Share Posted January 18, 2010 I want the engine bay as clean and empty as pos. Stick the engine on Ebay, then steam clean the hole? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 18, 2010 Share Posted January 18, 2010 Make one of these a feature? Quote Link to comment Share on other sites More sharing options...
