supradibbs Posted May 13, 2005 Share Posted May 13, 2005 Fitted new chris wilson pads and braided lines today bleed the system ran all new fluid through keept going untill there was no air and then went round a couple off times for good measure,but the bloody thing aint right i can get my foot almost to the floor and is spongy as hell so i guess there must be more air in the system bugger. The anoyining prt is that i did it at my dads place now the car is stuck at his untill i can get back over on Sunday. No supe all weekend sorry just needed to share Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted May 13, 2005 Share Posted May 13, 2005 not good news then. I'm hardly the most techi person about, but when I had this problem on my old car it turned out to be the brake cylinder seal had turned inside out, hence letting a bit of air in each time.... does it get firmer when you pump it? (ooh-er!). Quote Link to comment Share on other sites More sharing options...
supradibbs Posted May 13, 2005 Author Share Posted May 13, 2005 no it does not get any firmerrrrrrr mate Quote Link to comment Share on other sites More sharing options...
KatieC Posted May 13, 2005 Share Posted May 13, 2005 Laz had the same, did you bleed with the engine off, if so you will need to run the engine pump the brakes and then top up again before taking it out..... Hope this helps. Quote Link to comment Share on other sites More sharing options...
Amazing grace Posted May 13, 2005 Share Posted May 13, 2005 I am sure you will fix it over the weekend hun Good luck The car is looking absolutely fantastic inside and out and inthe engine bay i am so jealous!!!!!!!!!!!!!!!!!!!!!!!!! Regards, Sheena Quote Link to comment Share on other sites More sharing options...
terribleturner Posted May 13, 2005 Share Posted May 13, 2005 Same thing as me Wayne from last week. Did you try driving it gently to see which ones are and which arn't working?? As you know both my rears Ceased up. Scared to do the fronts now. Quote Link to comment Share on other sites More sharing options...
supradibbs Posted May 13, 2005 Author Share Posted May 13, 2005 Cheers guys and gals the brakes are working pulling all corners fine just the braking is crap and the peddle is very spongy just hope it aint the master cylinder will have another go on sunday oh and the engine was running when i bleed it Quote Link to comment Share on other sites More sharing options...
lovatt Posted May 13, 2005 Share Posted May 13, 2005 does indeed sound like the master cylinder to me mate, i have had this happen to me on other cars when im messing with the fluid Quote Link to comment Share on other sites More sharing options...
