NA-T kit
Dazzi
i would say 300ish with the 9psi spring and a little more with the 11psi. with the 9psi you are faster then a stock tt (just) speaking from experience...
11psi is pushing it if running stock HG and ecu. 9psi at the most id say on stock equipment.
stock static compression is just to high to run that sort of boost safely for long. Dont forget the advance in timing at 4500 rpm. To much boost + this = bad things.
Petty i havnt got the cash spare, id have this just to play about with it and see what the limits realy are
  • 2 weeks later...
  • 3 weeks later...
