Callaway Motorsport Posted January 16, 2010 Share Posted January 16, 2010 Hi guys, After seeing other people getting Bullseye turbo's, it finally gave me the bump i needed. I have been thinking about one of these since September of last year, when i spoke to one of the american guys who has a S472 on his with race cover. Not sure which in/ exducer sizes he has but i'm not comparing that anyway. It would be to replace my current HKS T04-R setup with .96 A/r and the goal would be to get a more reliable/ durable turbo (ball bearing), make some more power (700-800 WHP mark max) without maxing the turbos potential. But at the same time not loose the good spool and response i get from the current setup. Altough i have been following Jamie's progress with his billet turbo which is now giving interestingly high power, I have read and seen more info on the bullseye turbos recently with good and better results against other turbo manufacturers. I was wondering whether any of you experience guys could help me a little with your own experiences as to what turbo to go for, what size to upgrade to etc when going to a Bullseye setup, as they have many choices not only in compressor sizes, but also in the different housings etc. It would be choosing the easier way when just ordering a T72/78 just to make more power. But as said above, I would just like to hear some tips/ comments from others what there experience and or advice would be. Thanks PS: dyno sheet below, car is on stock fuel at the moment but will be a Stage 2 PHR kit going on to support the power... Be aware that the current status due to stock fuel is that its running @ 1.2 Bar when it can go to 1.6 (as per HKS spec) http://lh6.ggpht.com/_mZNTX4tRdck/Sz6KSLh3nOI/AAAAAAAACV4/jak8lFJ_f88/s512/Dyno%20run%20Re-Worx%202.jpg Crank HP http://lh6.ggpht.com/_mZNTX4tRdck/Sz6KSaeeCTI/AAAAAAAACV8/gswCPjjZzbE/s512/Dyno%20run%20Re-Worx%20small%201.jpg Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 16, 2010 Share Posted January 16, 2010 For 700-800rwhp you are going to need a fairly large turbo, id keep an eye on what Paul wiffins dyno sheet is like with the Bullseye S368. Quote Link to comment Share on other sites More sharing options...
