Project Blitz Posted January 15, 2010 Share Posted January 15, 2010 Just wondering if you guys use this method. plus how is the back end twitch on a supra when down gearing from high speed? (im refering to track driving mainly) Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 15, 2010 Share Posted January 15, 2010 Never done it myself, you would have to be very serious about going fast to warant it imo. Quote Link to comment Share on other sites More sharing options...
Project Blitz Posted January 15, 2010 Author Share Posted January 15, 2010 It's weird that cos the japs always use it So just wondered So say your high speed n down gearing does the rear stay put? Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 15, 2010 Share Posted January 15, 2010 So say your high speed n down gearing does the rear stay put? Yeah its fine as long as you dont down change to early. Quote Link to comment Share on other sites More sharing options...
Homer Posted January 15, 2010 Share Posted January 15, 2010 The only time I've ever found it useful is blipping the throttle on downshift on slight bends. On the road I've certainly never driven fast enough (nor have the skill) to do it while driving the car round a tight corner. Quote Link to comment Share on other sites More sharing options...
Project Blitz Posted January 15, 2010 Author Share Posted January 15, 2010 one of my fav drivers Tsuchiya-San uses it all the time, on the Togue battles as well. so just wondered if anyone uses on track driving Quote Link to comment Share on other sites More sharing options...
Guest MoeBlunt Posted January 15, 2010 Share Posted January 15, 2010 Isn't that double clutching...?! Because I used to do that when driving in the semi-pro rally in dubai and egypt... Quote Link to comment Share on other sites More sharing options...
n boost Posted January 15, 2010 Share Posted January 15, 2010 I use it on the down changes which helps crunching/missing the gear and overall smoother. Quote Link to comment Share on other sites More sharing options...
AJI Posted January 16, 2010 Share Posted January 16, 2010 (edited) Isn't that double clutching...?! Because I used to do that when driving in the semi-pro rally in dubai and egypt... Nope, that is the standard heel&toe method. I tend to use heel and toe for everyday driving...I know on the road its not going to find me any extra 10ths of a second but purely for the other reason of heel & toe in that down changes are much smoother. And I find it safer in the wet by removing the worry that the rears will not lock up if there is too much 'take up' on the drive train on downchange. On the track it really does give a more balanced car when braking. The weight transfer of the car stays smoothly at the front and doesn't 'jerk' around if the drivetrain were to suddenly 'search' for the revs needed for the lower gear if not heel and toe'ing. Edited January 16, 2010 by AJI (see edit history) Quote Link to comment Share on other sites More sharing options...
Kopite Posted January 16, 2010 Share Posted January 16, 2010 I tend to use heel and toe for everyday driving...I know on the road its not going to find me any extra 10ths of a second but purely for the other reason of heel & toe in that down changes are much smoother. And I find it safer in the wet by removing the worry that the rears will not lock up if there is too much 'take up' on the drive train on downchange. Not saying i'm any good at it Do find it a lot smoother like AJI says, problem i have is the footwear! Quote Link to comment Share on other sites More sharing options...
Chewie Posted January 16, 2010 Share Posted January 16, 2010 I use to heel and toe alot during my suped up Mini and 205 GTI days. Useful for simultaneous downshifting and braking like when you've gone into a corner too hot or want to shift weight for extra grip upfront. Also great for locking up the back on FWD for initiating a drift if you're too busy to tug the handbrake. Quote Link to comment Share on other sites More sharing options...
bignum Posted January 16, 2010 Share Posted January 16, 2010 I only use heal/toe on a damp or wet track as aj says it does help the car stay balanced and gives less chance of the backend locking up, i practice when i`m driving around in my transit connect van:) Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 16, 2010 Share Posted January 16, 2010 (edited) I tend to use heel and toe for everyday driving...I know on the road its not going to find me any extra 10ths of a second but purely for the other reason of heel & toe in that down changes are much smoother. And I find it safer in the wet by removing the worry that the rears will not lock up if there is too much 'take up' on the drive train on down change. Me too. Got these peddles fitted to make it easier thanks to Jezz. It makes a huge difference to the traction of the back end on down shifts, so much so the BMW M5 automatically matches engine rpm to the rpm of the clutch, so you can drop 3 or 4 gears in an instant without the risk of unbalancing the car. Edited January 16, 2010 by Terminator (see edit history) Quote Link to comment Share on other sites More sharing options...
Chewie Posted January 17, 2010 Share Posted January 17, 2010 Best to reset the brake and accelerator pedal at more or less the same height. Or get flexi jointed right ankle. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted January 18, 2010 Share Posted January 18, 2010 I also got me some aftermarked (actually toyotas own alu pedals from Whifbitz, they have a more OEMish look) and placed the speedo pedal a bit to the left side, to make the space between brake and speed smaller. This helps A LOT towards doing the heel-and-toe (well actually more left-n-right-side-of-foot) more fluidly without too much of a risk of slipping Quote Link to comment Share on other sites More sharing options...
Thorin Posted January 18, 2010 Share Posted January 18, 2010 I practise doing it on the road sometimes, but at speed on a track I'd probably fluff it up. (I also have the Toyota Alu pedals BTW) Quote Link to comment Share on other sites More sharing options...
