hp006 Posted January 15, 2010 Share Posted January 15, 2010 I have spent an hour searching for threads and cant find anything, dont think i can use this function as it never finds what i look for, anyway the problem: I have started to try and fit the braided hoses. Im starting at the rear passenger side. I have taken the wheel off and started undoing the bolt opposite the caliper that joins into the hose. I keep turning and turning this bolt and it still keeps turning, is there something i need to do to release the bolt. It has come up about 1/2 cm. Also when i look just below the bolt im undoing where do i put the spanner on to release this part of the hose, top suspension side. If someone can advise or point me in the direction for a thread i would appreciate it Thanks Link to comment Share on other sites More sharing options...
David P Posted January 15, 2010 Share Posted January 15, 2010 If you look closely, there are a pair of push in, pull out clips that hold it in place. Pull them out. Link to comment Share on other sites More sharing options...
hp006 Posted January 15, 2010 Author Share Posted January 15, 2010 thank u for that i have got that bit loose, im still having the problem the hose master cylinder side is still not coming out the hose. I have undone it as much as i can and all it does is turn. How do i pull the two hoses apart. Cheers Link to comment Share on other sites More sharing options...
David P Posted January 15, 2010 Share Posted January 15, 2010 It has probably been over tightened, and belled out the end of the pipe inside. Brute force and or maybe a new brake line I think? Link to comment Share on other sites More sharing options...
