Opinions needed on Idle issue please
miko_supra
Started the car up after changing some spark plugs today and the car just died, so I unplugged the idle control valve and it started fine with a high 1500-1700 rpm Idle. I reconnected the plug on the valve (engine still running) and nothing happened.
So I restarted the engine (valve still plugged in) and the car dies again. Do this a couple more times and eventually the car has a warm idle (under 1000 rpm) but the car is running VERY rich with black smoke out the back and it is hunting for an idle with revs constantly going from 500 to 750 rpm.
I've checked all the hoses and connections round the engine bay and I even removed my piggy back ECU and have it running on the stock to rule that out (made no difference btw)
So I took the whole control valve assy out of the car and dismantled it and gave everything a good clean. Everything seems to be moving ok.
Put it all back together again and the problem is still the same.
The last time I run the car was about a month ago when it ran fine and all I have done on the car since is spark plugs and a new FMIC.
Is this definatly just an Idle control valve issue guys? Would this cause the car to run very rich also.
Check the vacuum hosing around the MAP sensor. If it's off or holed, you'll be seeing atmospheric and fuelling for that, instead of a high vacuum.
If you have a boost gauge, see what it's reading.
-Ian
Hosing all looks ok. The boost gauge is reading -15 psi.
I've swapped over the o2 sensor and also swapped the ecu for spare ones I have, but they have not changed a thing.
Having a little bit of a play around, sometimes the car doesn't start at all, but when I unplug the the vacuum hose from the MAP sensor it starts (still runs rich and rough though) then when I plug the vacuum hose back into the MAP sensor the revs perk up a bit and then within 10 seconds it gets rougher and rougher till it eventually dies.
Now if the Sensor is plugged into the vacuum line at idle am I right in thinking that the fueling it will provide will be less than what it would be when unplugged and sensing atmospheric pressure. But then why would it then stall after 10 seconds??
I had an overfuelling issue a while back that took about 3 months to diagnose, and the oil got contaminated with fuel - but as it was never put under any sort of load it didn't do any damage.
I had to use an oscilloscope in the end to work out what was wrong, although these days the data the E-Manage can spit out is incredibly useful for diagnosing stuff. Don't suppose that's the piggyback ECU you have is it...?
I have a hks f-con fitted to the car. I just can't think what it could be. The car had been sitting for about 6 weeks and only has about 1/8 of a tank of fuel in it. I put a gallon in yesterday from a petrol can. The only thing I can do Is start changing parts over and that just gets expensive and annoying.
So what was wrong with yours in the end then?
  • 2 weeks later...
