dcarrter21 Posted January 14, 2010 Share Posted January 14, 2010 going to be taking the supra off the road for a few months. got alot of work to do on it! is it best to try n let the engine warm up now and again or just leave it? anything else i need to be aware of? cheers Link to comment Share on other sites More sharing options...
Geo Posted January 14, 2010 Share Posted January 14, 2010 i tend to turn mine over once, twice per week mate. let it run for a while then turn it off. Will always have a quick look for leaks etc. just to be on the safe side. Link to comment Share on other sites More sharing options...
dcarrter21 Posted January 14, 2010 Author Share Posted January 14, 2010 cheers. its used to being a daily driver so i think its going to like the break! its not going to like the drift season though! Link to comment Share on other sites More sharing options...
dude Posted January 15, 2010 Share Posted January 15, 2010 i tend to turn mine over once, twice per week mate. let it run for a while then turn it off. Will always have a quick look for leaks etc. just to be on the safe side. IMO not the best thing to do George, its allways in cold start mode and never being used you will just be loading it up and may be filling the sump with fuel slowly which will greatly reduce the efficiency of the oil!!!, I would only start it if I intended to go for a bit of a drive and get it properly warm. Link to comment Share on other sites More sharing options...
Geo Posted January 15, 2010 Share Posted January 15, 2010 IMO not the best thing to do George, its allways in cold start mode and never being used you will just be loading it up and may be filling the sump with fuel slowly which will greatly reduce the efficiency of the oil!!!, I would only start it if I intended to go for a bit of a drive and get it properly warm. Dude so basically if im starting her up, then to take her for a short drive, and get the temps up? Link to comment Share on other sites More sharing options...
dude Posted January 15, 2010 Share Posted January 15, 2010 Dude so basically if im starting her up, then to take her for a short drive, and get the temps up? Yes mate you are just loading everything up and the most wear you will inflict on that engine is when its cold!!!!! Engines that never switch off hardly wear out, if its garaged I would just leave it in there till the spring, put some carpet on the floor stop all draughts and put an oil filled radiator on, it will prob fire straight up come spring (or it would if Matt set up the cold start!!!) Link to comment Share on other sites More sharing options...
dcarrter21 Posted January 15, 2010 Author Share Posted January 15, 2010 so basicly store in a cool dry place?its going to be off the ground on axel stands anyway because ive got to do the clutch. do you think its best to do an oil change before as its due one at the moment. Link to comment Share on other sites More sharing options...
martini Posted January 15, 2010 Share Posted January 15, 2010 IMO not the best thing to do George, its allways in cold start mode and never being used you will just be loading it up and may be filling the sump with fuel slowly which will greatly reduce the efficiency of the oil!!!, I would only start it if I intended to go for a bit of a drive and get it properly warm. OK that's good to know. I actually only fire my car up fortnightly - is this a problem? The battery seems to survive (how long does it take to fully recharge with the engine on?). When I do fire her up, I then usually drive for over an hour/75 miles. Link to comment Share on other sites More sharing options...
edge Posted January 15, 2010 Share Posted January 15, 2010 Just get it on stands dave and forget about starting it up. If its due new oil then just put some new cheap crap in it and leave the old oil filter on aswel and do a propper oil and filter change before you put it back on the road. Link to comment Share on other sites More sharing options...
dude Posted January 15, 2010 Share Posted January 15, 2010 You can get a little OPTIMATE charger that will keep the battery nicely topped up, you just leave them attached and they charge when needed. Link to comment Share on other sites More sharing options...
SimonT Posted January 15, 2010 Share Posted January 15, 2010 You can get a little OPTIMATE charger that will keep the battery nicely topped up, you just leave them attached and they charge when needed. Exactly the little tool that i use on mine Good little bit of kit Link to comment Share on other sites More sharing options...
Geo Posted January 15, 2010 Share Posted January 15, 2010 You can get a little OPTIMATE charger that will keep the battery nicely topped up, you just leave them attached and they charge when needed. Exactly the little tool that i use on mine Good little bit of kit which one there is loads? Link to comment Share on other sites More sharing options...
steve spedd Posted January 15, 2010 Share Posted January 15, 2010 not this one? http://www.optimate-chargers.co.uk/?gclid=CMj7suDipp8CFZ1h4wodQBWr1A Link to comment Share on other sites More sharing options...
SupraRider Posted January 15, 2010 Share Posted January 15, 2010 Isn't the Optimate Charger 4 only for motorcycles? Will that be compatible with cars as well? not this one? http://www.optimate-chargers.co.uk/?gclid=CMj7suDipp8CFZ1h4wodQBWr1A Link to comment Share on other sites More sharing options...
steve spedd Posted January 15, 2010 Share Posted January 15, 2010 if you click on car trickle chargers on the link just above the product it sends you to that one, so i guess so* *waits to be corrected... Link to comment Share on other sites More sharing options...
Kev_A Posted January 15, 2010 Share Posted January 15, 2010 IMO not the best thing to do George, its allways in cold start mode and never being used you will just be loading it up and may be filling the sump with fuel slowly which will greatly reduce the efficiency of the oil!!!, I would only start it if I intended to go for a bit of a drive and get it properly warm. Ditto, mines probably been used twice in the last month but I never actually start unless I intend on driving it anywhere Link to comment Share on other sites More sharing options...
SimonT Posted January 15, 2010 Share Posted January 15, 2010 Isn't the Optimate Charger 4 only for motorcycles? Will that be compatible with cars as well? Yes mate they are for bikes as that what i originally purchased it for but work fine on cars Link to comment Share on other sites More sharing options...
