MaveriK Posted January 12, 2010 Share Posted January 12, 2010 Was to be fitted to my old pc before it went bang. It is one of the coolest things you can put in your PC, gives you multiple ports and smart fan control. http://www.kustompcs.co.uk/acatalog/2818.jpg The allinone is a stylish multi-function panel that is equipped with multi-slot card reader, temperature display with alarm plus RPM control and multi I/O ports, The allinone is installed in 5 1/4 device bay. The multi-slot card reader addresses all the popular memory cards and the 4 memory-slots are active, which allows copy/transfer of data between the different memory cards. An over temperature alarm can be set. The LCD shows 2 fan rpm’s and monitors 2 temperature zones. The multi I/O ports function in the front of a PC provides convenient cable connection, including USB/ IEEE1394/ audio/ video connectors/ SATA power/ SATA data. - Stylish push open front cover - Hi-speed USB 2.0 backwards compatible with USB 1.1 - 4 Memory slots addressing 9 memory card formats - All 4 memory-slots are active allowing cross format transfer - LED display indicating power on and drive access - LCD shows 2 fan rpm’s and monitors 2 temperature zones - Over-temperature alarm · Fan failure alarm - Compatible with Mo/Bo fan signal detection - 13 I/O ports - USB 2.0 x 2, IEEE1394 x 1, audio - speaker x 1, mike x 1, earphones x 1, memory card reader x 4, A/V x 1, SATA data x 1, SATA power x 1. £30 including delivery Link to comment Share on other sites More sharing options...
MaveriK Posted January 15, 2010 Author Share Posted January 15, 2010 For what its worth its going on Fleabay sunday so please let me know asap if your interested. Thanks Link to comment Share on other sites More sharing options...
