boromfccup Posted January 12, 2010 Share Posted January 12, 2010 (edited) can any one help me, i got some paint work done on my car and now its speedo has given up, but the rev counter works and now the over drive light flashes on and off, help would be appreciated, FIXED THANKS Edited January 12, 2010 by boromfccup (see edit history) Link to comment Share on other sites More sharing options...
pistonbroke Posted January 12, 2010 Share Posted January 12, 2010 Do you have a delimiter on the car? If so, I'd look into this first. There have been many reported problems in the past of cheap de-limiters failing causing issues. To more or less confirm it, check for disgnostic codes and see of 42 comes up. Link to comment Share on other sites More sharing options...
stevie_b Posted January 12, 2010 Share Posted January 12, 2010 (edited) As pistonbroke said, with the addition that speed converters often cause this as well as delimiters. Checking for error codes is the first thing to do. If the ECU has logged code 42, try checking the wiring on the speed converter assuming you have one. If the wiring's OK then remove or replace it. Edited January 12, 2010 by stevie_b (see edit history) Link to comment Share on other sites More sharing options...
boromfccup Posted January 12, 2010 Author Share Posted January 12, 2010 As pistonbroke said, with the addition that speed converters often cause this as well as delimiters. Checking for error codes is the first thing to do. If the ECU has logged code 42, try checking the wiring on the speed converter assuming you have one. If the wiring's OK then remove or replace it. cheers i had a thor deimeter/converter put in are these reliable, sorry to be stupid but how do i check for a code 42 thanks Link to comment Share on other sites More sharing options...
stevie_b Posted January 12, 2010 Share Posted January 12, 2010 (edited) The Thor ones are reliable: they're widely regarded as one of the best. However, like any electronic gizmo they're not guaranteed to be 100% foolproof. I'm in a similar situation to you actually. I too fitted a Thor DSC_TSD several years ago. In the last month or two I noticed the speedo wasn't working at all and the MIL (orange engine warning symbol on the right of the dashboard) was lit. This points to a fault to do with the speed converter part of the Thor unit (or equally likely, the electronic signals to/from the unit). I haven't got round to it yet but I'll take the dashboard fascia off, check all wiring/solder joints and if that looks OK, try to run the car (temporarily as a test) without a DSC. If that proves too fiddly, I'll probably just buy another replacement unit. Hover over the underlined "error codes" text in my post with your mouse: you'll need a paperclip and 3 mins of your time. Also verify that your MIL light is actually working at all by checking it gets lit when the ignition is at position 2 but the engine is off. Edited January 12, 2010 by stevie_b (see edit history) Link to comment Share on other sites More sharing options...
boromfccup Posted January 12, 2010 Author Share Posted January 12, 2010 hi thanks for response, i tied the easy option first as id read about it on here a couple of days ago, i disconnected the battery and done a reset and it worked all back up and running cheers for your help Link to comment Share on other sites More sharing options...
