Replacing discs on carbon clutch
csa
On an Exedy carbon twin disk, would it be fair to assume that it's the Intermediate plates that wear out first, or would it be the actual carbon plates. I'm thinking that the carbon plates should outwear the steel Intermediate plates easily.
What's your experience on this, and had any of you guys ever replaced either on your carbon clutches?
Edited by csa (see edit history)
I have no experience of carbon clutches in road cars, proper race ones are shimmed, AP has various publications on using and checking them, for example:
http://www.apracing.com/drawings/p14068.pdf
I suspect the Exedy one won't be very similar at all though, I recall seeing a photo of an Exedy carbon clutch and it looked like like a normal multi plate with funny linings. Exedy are local to me, but their products seem to go out of date very quickly so you can only get spares and info on very recent products. If I had to guess I'd say the carbon and the steel plates wil wear at fairly similar rates, and the steel ones may be prone to warpage.
AP carbon clutches need specialised care, and when worn, specialised set up back at AP. They are seriously costly, this is quite a cheap one:
http://froogle.motorsportworld.co.uk/framefix.asp?PID=1075954&ProductCode=CP7923-GH03-FN
Edited by Chris Wilson (see edit history)
