Guest 207 Posted January 11, 2010 Share Posted January 11, 2010 I couple months ago I had a front mount intercooler added to my Euro Spec TT. The only other parts installed are a Apexi exhaust with downpipe and a blitz intake. Now as soon as I get into load, 2 to 5 lbs the car breaks up, misfire and never gets above 3 lbs. I drive the car once a month and thought it might be a boost leak from the intercooler install. I finally got around to checking and I don't have a boost leak, so now what... I thought it might be the coil or coil connectors, but reading the forum it seems that only happens in higher boost levels... FYI the battery terminals touched the hood during the intercooler installation and shorted out the radio and amp. Is it possible this could have shorter something else out? Any idea where to turn would be helpful... Quote Link to comment Share on other sites More sharing options...
Guest 207 Posted January 13, 2010 Share Posted January 13, 2010 I couple months ago I had a front mount intercooler added to my Euro Spec TT. The only other parts installed are a Apexi exhaust with downpipe and a blitz intake. Now as soon as I get into load, 2 to 5 lbs the car breaks up, misfire and never gets above 3 lbs. I drive the car once a month and thought it might be a boost leak from the intercooler install. I finally got around to checking and I don't have a boost leak, so now what... I thought it might be the coil or coil connectors, but reading the forum it seems that only happens in higher boost levels... FYI the battery terminals touched the hood during the intercooler installation and shorted out the radio and amp. Is it possible this could have shorter something else out? Any idea where to turn would be helpful... Found the answer...the stereo amp was damaged and the car runs a bit too rich and the plugs were fouling. Need to find out why its so rich...thanks Quote Link to comment Share on other sites More sharing options...
Guest blownminiturbo Posted January 13, 2010 Share Posted January 13, 2010 you may need to drive the car more often aswell. or if you leave it running wait till its fully warmed up before shutting it down. Quote Link to comment Share on other sites More sharing options...
hodge Posted January 13, 2010 Share Posted January 13, 2010 Have you tried cleaning the O2 sensor then resetting the ecu. This cab cause hurrensous overfueling. Quote Link to comment Share on other sites More sharing options...
dude Posted January 13, 2010 Share Posted January 13, 2010 Do you have a BOV Quote Link to comment Share on other sites More sharing options...
