BMW 330Ci LHD to RHD conversion
ray007
Does anyone have any knowledge of the BMW 330Ci's imported from Dubai?
a Frend has imported one im thinking to buy however i dont know how much it would cost to convert the LHD over to RHD??
anyone know about this and how much and rules, legalities etc
any advice would be appreciated.
you can still import a LHD in the uk and drive it...you don't need to convert it to a RHD!
i know, but i dont think i can and i prefer RHD. any idea of costs of transferring? and i can get the car, 2004 330Ci auto for only aroung £3000. is it worth the headache?
Guest MoeBlunt
not really mate...These conversions are VERRRRY expensive and a real headache! Your better off buying one from here, it will work out cheaper!!
All sorts of steering components, dash and maybe the loom for it, pedals, more wiring, headlights and maybe a load of other stuff.
You may be able to get the required parts cheap but i would pass on a job like that unless i was being paid alot.
And air vent feeds, relays and fuse boxes = more wiring, mirrors, window wipers.
Are the bulkheads symmetrical? or will that need to be cut out of a donor car?
Edited by edge (see edit history)
guys the owner has just told me he can get it converted to RHD for no more than around £1100?? would it be worth it then if im getting the car around £4000 so al inn £5100 for a 2004 330ci?
All them parts and work for £1100. I would bite his hand off.
For £1100, I'd expect levers under the dash kind of conversion and not a complete dash, column and other such bits.
Surely a set of BMW headlights would be over £500 alone...
Exactly, I wouldn't trust any car let alone a performance car with a cheap conversion. If serious, do some research into conversions as some can make the car dangerous to drive and as for resale, if not done properly it would likely be worth far less than the original LHD due to the risk.
Just drive it LHD, every Tom, Dick & Harry has a BMW 3 Series... be a little different and stand out from the crowd. Plus it will be a an excuse to drive from London to France! I take it is an Auto, in which case it is even easier to drive. As everyone has mentioned to get it done properly it will cost a lot of money. Just get a quote of a full 3 series dash and you will get a rough idea.
